Page 1 of 2 1 2 LastLast
Results 1 to 25 of 49
Thread: All you need to know about sensors
    Aug 2004
    GY
    1.6 16v XEL Sport
    COOLANT SENSOR. Usually located on the cylinder head or intake manifold, this sensor is used to monitor the temperature of the engine’s coolant. Its resistance changes in proportion to coolant temperature. Input from the coolant sensor tells the computer when the engine is warm so the PCM can go into closed loop feedback fuel control and handle other emission functions (EGR, canister purge, etc.) that may be temperature dependent.
    Coolant Sensor Strategies: The coolant sensor is a pretty reliable sensor, but if it fails it can prevent the engine control system from going into closed loop. This will result in a rich fuel mixture, excessive fuel consumption and elevated carbon monoxide (CO) emissions - which may cause the vehicle to fail an emissions test.
    A bad sensor can be diagnosed by measuring its resistance and watching for a change as the engine warms up. No change, or an open or closed reading would indicate a bad sensor.
    OXYGEN (O2) SENSOR. Used on both carbureted and fuel injected engines since 1981, the oxygen (O2) sensor is the key sensor in the fuel mixture feedback control loop.
    Mounted in the exhaust manifold, the O2 sensor monitors the amount of unburned oxygen in the exhaust. On many V6 and V8 engines, there are two such sensors (one for each bank of cylinders).
    The O2 sensor generates a voltage signal that is proportional to the amount of unburned oxygen in the exhaust. When the fuel mixture is rich, most of the oxygen is consumed during combustion so there is little unburned oxygen in the exhaust. The difference in oxygen levels between the exhaust inside the manifold and the air outside creates an electrical potential across the sensor’s platinum and zirconium tip. This causes the sensor to generate a voltage signal. The sensor’s output is high (up to 0.9v) when the fuel mixture is rich (low oxygen), and low (down to 0.1v) when the mixture is lean (high oxygen).
    The sensor’s output is monitored by the computer and is used to rebalance the fuel mixture for lowest emissions. When the sensor reads "lean" the PCM increases the on-time of the injectors to make the fuel mixture go rich. Conversely, when the sensor reads "rich" the PCM shortens the on-time of the injectors to make the fuel mixture go lean. This causes a rapid back-and-forth switching from rich to lean and back again as the engine is running. These even waves result in an "average" mixture that is almost perfectly balanced for clean combustion. The switching rate is slowest in older feedback carburetors, faster is throttle body injection systems and fastest in multiport sequential fuel injection.
    If the O2 sensor’s output is monitored on an oscilloscope, it will produce a zigzagging line that dances back and forth from rich to lean. Take a look at the waveform on the opposite page - that’s what a technician wants to see when he checks the O2 - think of it as a kind of heart monitor for the engine’s air/fuel mixture.
    O2 Sensor Strategies: Unheated one- or two-wire O2 sensors on 1976 through early 1990s applications should be replaced every 30,000 to 50,000 miles to assure reliable performance. Heated 3 and 4-wire O2 sensors on mid-1980s through mid-1990s applications should be changed every 60,000 miles. On OBD II equipped vehicles, the recommended replacement interval is 100,000 miles. The O2 sensor’s responsiveness and voltage output can diminish with age and exposure to certain contaminants in the exhaust such as lead, sulfur, silicone (coolant leaks) and phosphorus (oil burning). If the sensor becomes contaminated, it may not respond very quickly to changes in the air/fuel mixture causing a lag in the PCM’s ability to control the air/fuel mixture.
    The sensor’s voltage output may decline giving a lower than normal reading. This may cause the PCM to react as if the fuel mixture were leaner than it really is resulting in an overly rich fuel mixture.
    How common is this problem? One EPA study found that 70 percent of the vehicles that failed an I/M 240 emissions test needed a new O2 sensor.
    MANIFOLD ABSOLUTE PRESSURE (MAP) SENSOR. This sensor is mounted on or connected to the intake manifold to monitor intake vacuum. It changes voltage or frequency as manifold pressure changes. The computer uses this information to measure engine load so ignition timing can be advanced and retarded as needed. It performs essentially the same job as the vacuum advance diaphragm on an old fashioned mechanical distributor.
    On engines with a "speed density" type of fuel injection, the MAP sensor also helps the PCM estimate airflow. Problems here may cause an intermittent check engine light (light comes on when accelerating or when the engine is under load), hesitation when accelerating, elevated emissions and poor engine performance. The engine will run with a bad MAP sensor, but it will run poorly. Some PCMs can substitute "estimated data" for a missing or out of range MAP signal, but engine performance will be drastically reduced.
    MAP Sensor Strategies:
    Some MAP sensor problems are not the fault of the sensor itself. If the vacuum hose that connects the MAP sensor to the intake manifold is loose, leaking or plugged, the sensor can’t produce an accurate signal. Also, if there is a problem within the engine itself that causes intake vacuum to be lower than normal (such as a vacuum leak, EGR valve that’s stuck open or leaky PCV hose), the MAP sensor’s readings may be lower than normal.
    THROTTLE POSITION SENSOR. Mounted on the throttle shaft of the carburetor or throttle body, the throttle position sensor (TPS) changes resistance as the throttle opens and closes. The computer uses this information to monitor engine load, acceleration, deceleration and when the engine is at idle or wide open throttle. The sensor’s signal is used by the PCM to enrich the fuel mixture during acceleration, and to retard and advance ignition timing.
    Throttle Position Sensor Strategies: Many TPS sensors require an initial voltage adjustment when installed. This adjustment is critical for accurate operation. On some engines, a separate idle switch and/or wide open throttle (WOT) switch may also be used. Driveability symptoms due to a bad TPS can be similar to those caused by a bad MAP sensor: The engine will run without this input, but it will run poorly.
    MASS AIRFLOW SENSOR (MAF). Mounted ahead of the throttle body on multiport fuel injected engines, this sensor monitors the volume of air entering the engine. The sensor uses either a hot wire or heated filament to measure both airflow and air density.
    MAF Sensor Strategies: The sensing element in MAF sensors can be easily contaminated causing hard starting, rough idle, hesitation and stalling problems.
    VANE AIRFLOW SENSOR (VAF). The VAF has a mechanical flap-style sensor that is used on Bosch and other import multiport fuel injected engines. The function is the same as a mass airflow sensor, but air pushing against a spring-loaded flap moves a rheostat to generate an electronic signal.
    VAF Sensor Strategies: The drivability symptoms for the VAF are the same as those of a mass airflow sensor if the sensor fails.
    MANIFOLD AIR TEMPERATURE (MAT) SENSOR. Mounted on the intake manifold, this sensor changes resistance to monitor incoming air temperature. The sensor’s input is used to adjust the fuel mixture for changes in air density.
    MAT Sensor Strategies: Problems with the manifold air temp sensor can
    affect the air/fuel mixture, causing the engine to run rich or lean.
    CRANKSHAFT POSITION SENSOR. Used on engines with distributorless ignition systems, the crankshaft position sensor serves essentially the same purpose as the ignition pickup and trigger wheel in an electronic distributor. It generates a signal that the PCM needs to determine the position of the crankshaft and the number-one cylinder. This information is necessary to control ignition timing and the operation of the fuel injectors. The signal from the crank sensor also tells the PCM how fast the engine is running (engine rpm) so ignition timing can be advanced or retarded as needed. On some engines, a separate camshaft position sensor is also used to help the PCM determine the correct firing order. The engine will not run without this sensor’s input.
    There are two basic types of crankshaft position sensors: magnetic and Hall effect. The magnetic type uses a magnet to sense notches in the crankshaft or harmonic balancer. As the notch passes underneath, it causes a change in the magnetic field that produces an alternating current signal.
    The frequency of the signal gives the PCM the information it needs to control timing. The Hall effect type of crank sensor uses notches or shutter blades on the crank, cam gear or balancer to disrupt a magnetic field in the Hall effect sensor window. This causes the sensor to switch on and off, producing a digital signal that the PCM reads to determine crank position and speed.
    Crank Position Sensor Strategies: If a crank position sensor fails, the engine will die. The engine may, however, still crank but it won’t start. Most problems can be traced to faults in the sensor’s wiring harness. A disruption of the sensor supply voltage (Hall effect types), ground or return circuits can cause a loss of the all-important timing signal.
    KNOCK SENSOR. The knock sensor detects engine vibrations that indicate detonation is occurring so the computer can momentarily retard timing. Some engines have two knock sensors.
    Knock Sensor Strategies: A failure with the knock sensor can cause spark knock and engine damaging detonation because the PCM won’t know to retard ignition timing if knock is occurring.
    BAROMETRIC PRESSURE (BARO) SENSOR. The baro sensor measures barometric pressure so the computer can compensate for changes in altitude and/or barometric pressure that would affect the fuel mixture or timing. Some MAP sensors also perform this function.
    VEHICLE SPEED SENSOR (VSS). The vehicle speed sensor, or VSS, monitors vehicle speed so the computer can regulate torque converter clutch lockup, shifting, etc. The sensor may be located on the transmission, differential, transaxle or speedometer head.
    Vehicle Speed Sensor Strategies: A problem with the vehicle speed sensor can disable the cruise-control system as well as affect transmission shifting and converter engagement.
    Replacing a sensor won’t solve a drivability or emissions problem if the problem isn’t the sensor. Common conditions such as fouled spark plugs, bad plug wires, a weak ignition coil, a leaky EGR valve, vacuum leaks, low compression, dirty injectors, low fuel pressure or even low charging voltage can all cause driveability symptoms that may be blamed on a bad sensor. If there’s are no sensor-specific fault codes, these kinds of possibilities should be ruled out before much time is spent on electronic diagnosis.
    Jun 2004
    In a hole
    Astra GTE mk2 8v
    Re: All you need to know about sensors
    someones been swotting up on their textbooks!
    I have no idea which of those sensors i have, except the coolant one of course
    Dec 2002
    Beckenham
    Calibra 2.0 16v Auto
    steve,
    could i copy and paste this onto the Calibra website ?
    Cheers
    Pete
    MIGWeb User James82's Avatar
    Mar 2004
    Northamptonshire
    MK3 Astra Sport 2.0L
    Thats going into my bookmarks! Top man
    Mar 2002
    Hampshire - UK
    C20LET Mk4 Astra
    nice one.
    C20LET Mk4 Astra
    247.4 bhp @ 4160 rpm & 315Ibs @ 4030 rpm
    Jan 2003
    Calibra V6 SE9 1997
    Thumbs up Re: All you need to know about sensors
    Excellent work, and an excellent read thank you! And with mine running lumpy (occasionally) its good to see what function they all play.
    For example I now know to forget a crank shaft sensor error, because the car runs every day, so it isn't that!
    Feb 2002
    West London/swansea
    Corrado G60, Vectra GSi
    can this one be made a sticky??
    Quote Originally Posted by Johnny A
    if you want something done right, bodge it yourself
    May 2002
    Essex
    Vectra DTI 2.0 -
    Please post as a sticky
    Apr 2002
    cheltenham
    Mk3 astra sport
    Hate to be picky, but the bit about crank position sensor isn’t entirely correct. my engine (C18XEL) will run (in "limp home mode") with the CPS disconnected!!!
    I guess engines without cam position sensor couldn’t run, but engines with cam position sensors can run on that data only.
    Feb 2006
    very informative thread, have 2 opel, 2000 vectra and omega, the omega temp gauge is not working though, i took all the sensor of the vectra so i can compare it to the omega, that i thought would relate to the engine temperature and a mechanic's advise that the sensor is underneath the ignition coil of the engine and i can pinpont if the problem is the sender or the gauge itself. the vectra's temp gauge is working after taking all the sensor. could you assist me on the precise location of the temp sensor.
    Feb 2006
    sorry about that, forgot to tell the engine model, they both have the same engine x20xev.
    Jun 2005
    Gatwick
    Clio 182
    Why dont we have a section dedicated to decent threads like this one? Like a tutorial section, to seperate info like this from questions?
    Dec 2004
    Hampshire
    Focus mk5/Astra mk5
    Bump , this is so handy
    I haven't failed. I've just found 10,000 ways that won't work
    Sep 2005
    Leigh, Lancashire
    Opel Vectra GSi 2000
    thanks for taking the time out.. Just the information I was looking for that
    Finn
    Mar 2005
    Armagh
    Vauxhall Calibra V6
    Top one stevejknight!
    I'm sure we all appreciate the efforts to put this all in here for us!
    Cheers
    0 to 60 in my car!
    Mar 2002
    suffolk
    Corsa Tbo KTM SMoto
    what about the cam sensor?
    www.wix.com/vxlgsi/zxr-750-r
    Jul 2006
    Top man steveknight.
    Just the type of info ive been looking for. The old astra cdx 1.8 16v (2000)
    has been a bit lazy when pulling away from standstill and has the odd 'hunt'
    now and again. will go back to my mech with a bucket full of suggestions!
    No doubt costly for me but what the hell !
    May 2001
    South Wales
    Nippy Cav Turbo
    found this thread using google and typing in C20LET VSS! lol
    My ecu is bring this code 24 up on my c20let..how do i fix it?
    and where is the sensor on a cav turbo
    cheers adam
    Jul 2006
    tyldesley/manchester
    Astra 1.7 dti 00
    this company manufacture sensors http://delphi.com/manufacturers/auto/sensors/et/
    click on the sensor to see images
    Jul 2006
    Astra 1.7 dti 00
    http://www.acdelco.com/html/as_guide_main.htm check out what sensor and where
    Jul 2006
    BEDFORDSHIRE
    VECTRA 99 ESTATE 1.8
    All good!!!!!
    The greatest trick the devil ever did was convince the world he never existed
    Aug 2006
    worksop
    gttdi golf, cav turb
    nice 1 mate, think u have just confirmed my problem, any 1 know if the xe lambda sensor is the same as the let or where i can get 1 from cheap ( £95 new at regal )
    Jul 2006
    Gloucester
    cavalier 1800i(1995)
    Hope someone can help!!!
    I have a Cavalier 1800 running a Multec Single Point Injection.
    Problem statred with drop in power while travelling, then lack of power causing a stall after which would not start again!!!
    Started first time next day but very lumpy, then just cut out altogrther. Started first turn of key then cut out again!!
    Seems very intermittent runs for 2 mins or 45 mins before cutout.
    Thought it could be fuel so replaced fuel filter and put injector cleaner through it.
    No better!!!
    Have replaced spark plugs, HT leads, Dizzy and rotor arm.
    Seems better but not right.
    Just took it out for a blast, it ran like a dream.
    Left it for half an hour took it out again, cut out at first junction, started eventually, pulled off ok but very errattic in 2nd and 3rd gear, slip the clutch loadsa revs and it smooths out a bit.
    Seems very intermittent, could this be a sensor problem???
    Any help is appreciated, Cheers Matt
    Aug 2004
    GY
    1.6 16v XEL Sport
    Before chaning sensors, check all your eathing points.
  26. #25
    Sep 2006
    wakefield
    clio 182
    top lad thanks a lot 4 tht
  1. 30-11-2011, 12:45
  2. 07-11-2011, 10:24
  3. 01-11-2011, 23:41
  4. 01-11-2011, 19:07
  5. 01-11-2011, 18:26
  6. 01-04-2011, 08:04
  7. 05-03-2011, 17:39
  8. 20-09-2010, 23:33
  9. 30-08-2010, 22:47
  10. 22-07-2010, 13:28
  11. 25-06-2010, 21:20
  12. 05-06-2010, 05:58
  13. 22-05-2010, 13:47
  14. 18-04-2010, 22:25
  15. 03-02-2010, 20:46
  16. 03-02-2010, 20:19
  17. 23-01-2010, 20:22
  18. 14-03-2009, 16:35
  19. 13-03-2009, 14:05
  20. 07-03-2009, 19:34
  21. 24-01-2009, 18:35
  22. 24-01-2009, 18:34
  23. *Clix
    Refback This thread
    07-10-2008, 17:14
  24. 04-10-2008, 17:45
  25. 14-09-2008, 10:12
  26. 11-09-2008, 01:09
  27. 11-09-2008, 00:36
  28. 21-04-2008, 22:31
  29. 16-04-2008, 17:30
  30. 30-03-2008, 17:05
  31. 13-09-2007, 13:35
  32. 13-09-2007, 12:30
  33. 13-09-2007, 12:01
  34. 01-09-2007, 00:31
