Let bottom crank pulley bolt
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
Thread: Let bottom crank pulley bolt
    Jan 2003
    Glasgow/scotland
    go on .. how do u get it off?? is there a secret code??? lol
    halfway through a let conversion and i got stuck as i need to change the oil pump and the crank pulley bolt won;t come off.. its feckin solid. tried heatin.. big bars.. swearing.. pretending i'm not gonna talk to it all week... stadning on it.. shouting adn it still didn;t budge so i'm stuck
    anyone got any good ideas. only one is to get it to someone with a n oxy ocetalene thingy so i can heat it up. help!
    To infinity and beyond
    Dec 2001
    Chelmsford, Essex,
    Astra1.8, Zaf1.8/1.9CDTI
    Re: Let bottom crank pulley bolt
    3 foot breaker bar, with a scaffy pole on it.
    Jan 2003
    Glasgow/scotland
    Thread Starter
    i tied a 3 foo tpole.. think its better to use that than heat? i could go "borrow" a bigger bar i guess
  5. Remove Advertisements
    Dec 2001
    Chelmsford, Essex,
    bigger bar
  7. #5
    Jan 2003
    Glasgow/scotland
    Thread Starter
    yes sir.. will try that... also need to get a 1/2 bit for the bolt on it.. keeps breakin converters
  8. #6
    MIGWeb User the_fbi's Avatar
    Apr 2004
    Oxfordshire, UK
    '96 Calibra Tur
    Find somebody with a windy gun and a compressor you can borrow.
    Failing that, and this is a trick used by karters, stick the socket on a variable speed drill with a clutch and a hammer action. (Karters use a cordless with hammer and clutch to do their wheel bolts.)
    A few seconds with the hammer knocking on the clutch and it may come undone.
  9. #7
    Jan 2003
    Glasgow/scotland
    Thread Starter
    buzz gun was used and failed miserably i'm afirad.. as ian (oo1) said its torques to 250 nm and buzz guns will do 200 so no hope for it supposedly..
  10. #8
    Sep 2003
    South London
    Without Due Care
    i hope i dont have this problem :/
  11. #9
    Jun 2003
    Plymouth
    Omega Elite
    i used a slightly unorthodox method.........
    I set a breaker bar so it was wedged against the floor and then started the engine.....making sure the HT lead was disconnected.
    Worked after the 3rd attempt.
    I only 'flicked' the started so as to shock the bolt
  12. #10
    Jan 2002
    ayrshire scotland
    like a saint-9points
    did you get it mate? ive got a bar i have modified that bolts onto the other side of the crank(requires clutch and flywheel off) to hold the crank from the other side while smoeone abuses the crank nut with a 3ft bar.
    ps get a half inch socket AT LEAST as anything smaller wont cop it..
    rodgerq
  13. #11
    Jan 2003
    Glasgow/scotland
    Thread Starter
    rodger we didn;t and we have the flywheel off so that we can use the xe bits for clutch but we bend all the bolts when we use them to ut a rod in them...
    i'd say id come up n borrow ur tool but i can't as the astra is now engine less.. bollocks.. i'm away to find a massive pole
  14. #12
    Jan 2002
    ayrshire scotland
    frazz ill be in glasgow in a couple of hours mate. ill see if i can find the bar in my tip of a garage and bring it up. where you stay then? could you get into the city centre?
    you needing a bar and 1/2" socket aswell?
    rodgerq
  15. #13
    Jan 2003
    Glasgow/scotland
    Thread Starter
    i'm n southside mate. giffnock way ... i could deffo jump ina bus and get u in town centre mate.. could do with the socket and that tool if thast ok... i'll give u a call in half an hour mate..
    Fraz
  16. #14
    Jan 2002
    ayrshire scotland
    ok. lol better bring a bag or something as you dont want the old bill seeing you walk about wae two 3ft bars. lol
    rodgerq
  17. #15
    Jan 2003
    Glasgow/scotland
    Thread Starter
    good call.. cheersmate
  18. #16
    Nov 2002
    Wigan
    Astra G C20LET
    hmmm.....why does everyone allways choose the hard way, cut the head off with a dremmel multi then it will just wind out by hand....easy
  19. #17
    Jan 2003
    Glasgow/scotland
    Thread Starter
    hows that gonna work?? the whole thread will be stuck in then
  20. #18
    Jan 2002
    ayrshire scotland
    he has a point fra. its below the head that rusts on so when you cut the head off the thread just unscrews, but i like the satisfaction of gettin it off with the bars. anyway ive had a look and i cant find the ***kin bar for the flywheel but ive got rhe breaker bar and socket you are welcome to use them if you want.
    do you have a dril and some decent sized(and sharp) drill bits by any chance?
    rodgerq
  21. #19
    Jan 2002
    ayrshire scotland
    fraz ill be in glasgow between 1 and 2 mate. say half 1 outside the train station on union street? does that suit you? give me bell mate
    rodgerq
  22. #20
    Jan 2003
    Glasgow/scotland
    Thread Starter
    ok i'll try the huge bar texhnique first.. will it ddeffo just pull out if i cut the head off? its deffo not goona be all seized in?
    cheers rodger
  23. #21
    Northeast Kent
    its not rust thats holding it in, its the fact its done up to over 200lbf-ft
    ive done the starter method twice, and a bar method once. the key to the bar method is locking the crank effectivley. very very hard without a flywheel on. block of wood between the big end and the edge of the block maybe ?
  24. #22
    Jan 2002
    ayrshire scotland
    i always remove the flywheel to do it. obviously not practical when the engine is in the car, thats when the starter method is used. but engine out i use this on the crank
    never failed me yet
    rodgerq
  25. #23
    Jan 2003
    Glasgow/scotland
    Thread Starter
    wish that bar i had was as big as that!! lol.. ahwell six fot pole and that bar bolted up here we go!
  26. #24
    Jul 2003
    Near Oxford
    E30 24v Turbo, BTCC
    I used the 1 ton gun at work. Its used for cracking off (ooh er) dumper wheels etc. It is torqued-up to 250Nm, so it will be fecking difficult to undo.
  27. #25
    Jan 2003
    Glasgow/scotland
    Thread Starter
    i know.. i'm not looking forward to it...
