Hey peeps, just another couple of quick questions....
Right, LET is going to be out of a Calibra, now how will I fix the PAS pump and alternator? Will I have to use an XE bottom pulley with the thin belts? Will this fit the LET without any problems?
I assume the Astra PAS pump will bolt straight on, what about the alternator fixings?
Exhaust wise I have a full longlife system on there at the moment that was made for the XE, now can I still use the system and have a piece made from the turbo down pipe to the rest of the system or will I have to have a whole new system made? Not sure what diameter the pipe work is, do I have to have a 2.5" system for the LET?
That’s about it for now me thinks....
Cheers for any help.... :beer: :beer:
