big fuel problem
Results 1 to 11 of 11
Thread: big fuel problem
    Jul 2004
    south central
    1989 nova 1.0
    big fuel problem
    i have a very big problem with my mk2 sri 18SE
    i have replaced all of the fuel lines in the car and put a new fuel filter on none of fuel lines leak but i put 5 petrol in the car and only got 20 miles out of it.
    i recently fitted a 2.0 16v digital dash to the car and after 20 miles the fuel warning light startet flashing.
    anyone got any ideas??
    Dec 2000
    Gloucester
    3MW B18iS
    Re: big fuel problem
    Well, it's either leaking somewhere or it's burning it.
    No, now f*** ***.
    Jul 2004
    south central
    1989 nova 1.0
    Thread Starter
    definatly no leaks i spent 15 minutes under the car checking all the fuel lines while the engine was running how would the car be burning it and how do i get it sorted
  5. Remove Advertisements
    Aug 2002
    Near Gt Yarmouth
    Astra Coupe 2.2 Combo Van
    Could be a mis-match between fuel sender and gauge,also gauges aren`t really the most accurate of things
    Need custom t-shirts?...www.deathgimp.co.uk
  7. #5
    Mar 2003
    Ayrshire, Scotland
    Astra Coupe Turbo P1
    maybe leaks underload, get someone to rev it up see then, did u actually run out of petrol? or u going by the dash? maybe just the sender is dodgy?
  8. #6
    Jul 2004
    south central
    1989 nova 1.0
    Thread Starter
    no dosent leak under load already tested that didnt run out of fuel either this is just to the point that the fuel light comes on i was wondering if the gte 16v digi dash reads a different way to the 1.8 sri sender unit also the sender unit may be sticking is that a fuel tank off job to look at it
  9. #7
    Mar 2003
    Ayrshire, Scotland
    i know on my old sri 8v i had to take the tank out, as it was a lot easier to get the sender unit out instead of faffing about, but that was because i had a out of tank fuel pump , i think the intank pumps ones have also got the sender under the rear seat
  10. #8
    Jul 2004
    south central
    1989 nova 1.0
    Thread Starter
    mine has an out of tank pump aswell there are two wires going to it if they were the wrong way round would it make a difference
  11. #9
    Mar 2003
    Ayrshire, Scotland
    doubt it those wires r just 0v and 12v power supply mate thats all, they can only go on one way because the crimps r certain size, unless they where cut off andy k should be able to tell u what colour wire goes to what side. i can remember
    on the fuel tank u will see another wire comming out of it, and a fuel line which is the return feed, well that is the sender unit , have to drain tank out then remove it and put new one in
  12. #10
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    When the fuel light comes on you could have a gallon in there,more than likely just swapping the dashs over,and the way the digi dash reads the signal.
  13. #11
    Jul 2004
    south central
    1989 nova 1.0
    Thread Starter
    again thats wat i was wondering the digi dash misleading me and telling me i am running out of petrol when i aint
