c20let + F20 box which clutch??
Results 1 to 12 of 12
Thread: c20let + F20 box which clutch??
    Aug 2004
    london
    93 nova c20let
    can anyone help im running an F20 gearbox on a c20let with a turbo flywheel, which clutch should i use? Cossvaux have supplied me a 5-speed clutch which ive fitted but im not sure if its right theres loads of slack on the cable? What are the main dirrerences between 5 and 6 speed clutches is it just the clamping pressure? ive heard people use a 5 speed disc and 6 speed cover could this be my problem?
    DannyBoy16VDannyBoy16v
    Mar 2003
    Staffs
    Legacy gtb
    Re: c20let + F20 box which clutch??
    If your running F20 you will nedd the clutch for that box the turbo 1 doesn't fit. Prob best get an uprated 1 tho cuse it'll eat that one quite quick.
    Dec 2003
    north east
    ASTRA VXR 280bhp
    i used the calibra turbo flywheel and cover plate, and an astra gte friction plate and thrust bearing. lasted a while as well.
    ASTRA VXR 5000 miles
    full miltek
    stage 2 remap
    ...... now sat on my drive!
  5. Remove Advertisements
    Aug 2004
    london
    93 nova c20let
    Thread Starter
    any ideas why iv got so much play in the cluth fork? i can move it back and forth? everything is bolted up properly?
  7. #5
    Dec 2001
    Chelmsford, Essex,
    Astra1.8, Zaf1.8/1.9CDTI
    you will need the F20 clutch disc, as the splines are different on the F28
  8. #6
    Aug 2004
    london
    93 nova c20let
    Thread Starter
    can i use the f20 cover plate or do i have to use the f28 cover plate?? its just taken me 2 evenings to get the bl dy thing back together and in the car
  9. #7
    Jan 2002
    ayrshire scotland
    like a saint-9points
    you need to remember there are two pairs of itmes you need to match
    1st one is the flywheel and pressure plate. these need to be for the correct application
    2nsd is the gearbox and friction plate. as above.
    its normal for the cltucth arm to move back and forth a bit
    rodgerq
  10. #8
    Dec 2001
    Chelmsford, Essex,
    you can use whatever clutch fits your flywheel, as long as you use the F20 disc.
    Pot XE/LET, or flat XE, all will work.
  11. #9
    Jan 2003
    Glasgow/scotland
    where can i buy just a new friction plate for an f20 box guys??
    To infinity and beyond
  12. #10
    Dec 2001
    Chelmsford, Essex,
    Vauxhall, Autovaux etc..
    I'd go with an uprated one though on a LET/F20 so Helix or AP.
    Try demontweeks.
  13. #11
    Jan 2003
    Glasgow/scotland
    when i'm gettin a friction plate for this conversion autovaux r askin for a n engine number. i'm guessin this to determine whether i'm using a pot type or flat flywheels. which do i use and can someone give me an engine number if its the pot type as i ony have a flat type 20 xe engine number to give them.. please??
    cheers
  14. #12
    Dec 2001
    Chelmsford, Essex,
    Don't know what the difference in Clutch disc is.
    I assumed they were the same.
    Code:
      1  DISC,ASSY.,CLUTCH                                                -14128448        1    90369275     6 64 190
     90369275
      1  DISC,ASSY.,CLUTCH                                     14128449   -                1    90443470     6 64 202
     90443470
      2  COVER,AND PRESSURE PLATE,                                        -14128448        1    90297249     6 66 110
         ASSY.,CLUTCH
     90297249
      2  COVER,AND PRESSURE PLATE,                             14128449   -                1    90443334     6 66 010
         ASSY.,CLUTCH
     90443334
