any 1 got any pics on the wireing on the reverse gear looks like there should be a y lead or something from the plug closest to the injectors to the switch and i take it the other plug futher down is the 1st gear
im using a f20 atm as far as ive worked out open circuit is 1st gear closed circuit (wire joined togther) is other gears is this correct ?
reverse switch y lead ? so the revse light switch connects to reverse light plug (on car) and then to engine loom
