Inlet Diameter
343 views 4 replies 1 participant last post by  Davcohen
#1 ·
i want to pick myself up a cone filter but im not sure if im best sticking it on the end of the inlet mainifold or ignoring that and sticking it on the end of the pipe which goes into the other side of the inlet
assuming i should stick it on the end of the inlet, should i have a pipe made which allows the filter to sit directly by the front grill instead of being at the back of the engine?
if someone could verify the size of the inlet aswel, in cm or inch's or both even, on the 1.7 lump
