the marks on the top pulleys should face directly up,get the eng round to tdc on cylinder one and the two notchs should face up and the pointer near the bottom crank pulley should point at the notch on the crank pulley
on the left cams the marks line up with the cam cover and face away from each other
on the right cams the line up with the cam cover and face toward each other
