weird noise from fuel tank
Results 1 to 2 of 2
Thread: weird noise from fuel tank
    Jun 2004
    vaux cav 2.0CDX 1994
    Question weird noise from fuel tank
    can anyone help me?every time i open the fuel filler cap i get a loud hissing sound like a release of air,and when filling up at the pump,the trigger on the fuel nozzle justs keeps clicking unless i spend a bit of time trickling it in,does anyone know where to start to find the problem and could this be part of the problem i've been having with the car these last few weeks,ref my last thread 2weeks ago,many thanks in advance,dave
    Jul 2000
    Re: weird noise from fuel tank
    breather hose is blocked. whats happening is you fill it with fuel, and as the fuel is being used, its leaving a vacuum in the tank. when you release the cap the noise you hear is the air rushing in. This could cause running problems as on low fuel the pump will struggle to draw fuel.
    for a quick solution drill a 2mm hole in the fuel cap.
    ideally get underneath and remove the tank, and give all the hoses a clean out
