hi peeps here u go
wires under the bonnet
1,brown and green and a brown to the plug in the sunmp
2, 1 straight black
3, brown-black and brown and white
and fuel lines which way they go
the 2 pipes oin the header tank
the ecu in the car,
1, red-blue wire
2, red-black
3, straight green
4, red0white
5, black and red
6, red-purple has it owns conector
7, black
8, black
pipes under the bonnet
1, the pipe off the eco tec pipe if u get me
2, pipe off the left side off the engine under the injectors
3, bottum off the coolent bottle pipe where does it go
4, and there is a pipe off the block under the distributor box where does it go to
5, and there is a pipe on the cooper pipe that feed the engine where does that go 2
thats peeps
