XE conversion shopping list; mk3 Astra
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 29
Thread: XE conversion shopping list; mk3 Astra
    Berkshire
    BMW Beauty
    Post XE conversion shopping list; mk3 Astra
    I've got these parts already:
    XE, ECU & Loom, F20, GTE Rad, Driveshafts (tho may need better ones!),
    Hubs front & rear, GTE 16v brake calipers discs & pads,
    headbolts, ARP con rod bolts, all gaskets, oil pump o-ring, oil filter, cambelt, waterpump, Idler Pulley & tensioner, new clutch
    Spax shocks & springs ....
    So this is the list needed so far... wanna make sure I got everything!
    i. Metal engine mounts, all 3 ...from mk3 Astra/Cav 2 litre, or big block...
    ii. Rubber engine mounts (for c20xe, mk3 Astra)
    iii. 5 exhaust rubber mounts for Astra GSi (3 backbox, 2 centre section)
    iv. Handbrake cable (for rear disc conversion)
    v. Handbrake brackets (any more gen on this?)
    vi. Heater matrix hose feed (for GTE??)
    vii. Both fuel hoses from bulkhead to engine
    viii. HT leads... BERU
    ix Spark Plugs ..single electrode from Vaux
    x. Oil ...Vaux Semi-Synth 10/40w
    xi. Air Filter
    xii. Fuel Filter
    xiii. Suspension bushes:
    ......Front: 6 poly anti-roll bar bushes, 4 rubber wishbone bushes
    ......Rear: 2 poly anti-roll bar bushes, 2 poly rear beam bushes
    Anything missing??
    Last edited by xx 5id xx; 18-06-2004 at 11:19. Reason: Updated with outstanding parts required, and some that have been purchased.
    Jul 2000
    Re: XE conversion shopping list; mk3 Astra
    both fuel hoses, from bulkhead to engine.
    mounts need to be from mk3 astra or mk3 cav.
    why do you need better driveshafts? are yours knackered? mk3 cav 2.0 ones are fine
    BRB
    Gagged
    Sep 2002
    wiltshire
    astra 888 nova xe
    [QUOTE=xx 5id xx
    have you got the handbrake brackets?
  5. Remove Advertisements
    Jul 2000
    Sid, exhaust gen.. go to local exhaust place and get a big bolt on bracket for the backbox, they use them on bmws and the like.. then clamp it around your gsi backbox and you can hang it on the original astra mount, instead of messing about welding.
    did this on mine no probs
    BRB
  7. #5
    Berkshire
    BMW Beauty
    Thread Starter
    No... will add them to the list. Cheers.
    go to local exhaust place and get a big bolt on bracket for the backbox, they use them on bmws and the like... did this on mine
    Got a pic please?
  8. #6
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    Hi Sid, why do you need a new clutch? Did one not come with your box?? Or is it just a good idea to get a new one?
  9. #7
    Jul 2000
    no pic, its like a big bracket with a hook on it, go and ask your local exhaust place, they'll have loads
    BRB
  10. #8
    Oct 2002
    Corrrrnwaaaaal
    Audi S3
    do you need different rubbers for the centre section of exhaust then?
    Well slap my trumpet shifter!
  11. #9
    Jul 2000
    nope
    BRB
  12. #10
    Oct 2002
    Corrrrnwaaaaal
    Audi S3
    cool.
  13. #11
    Jul 2000
    I put a full magnex astra gsi exhaust system onto my 5 door mk3 and only mod was a big bracket for the rear box.
    BRB
  14. #12
    Berkshire
    BMW Beauty
    Thread Starter
    Quote Originally Posted by Cesaro
    It came with the box ...but I'd just rather get a new one.
    Rather replace now while its relatively easy to do!
    then sell the 2nd hand one, if anybody wants it??
  15. #13
    Berkshire
    BMW Beauty
    Thread Starter
    Suspension Bushes:
    PowerFlex
    http://www.powerflex.co.uk/products....6&catalog=0436
    SuperFlex:
    http://www.superflex.co.uk/superflex...nge_index.html
    Either gonna get Vaux rubber ones, or maybe some poly ones...
    rubber if they will last, as softer for a more comfy ride (less bumpy)
    >> Do I need wishbones, bumpstops, and anti-roll bars??
  16. #14
    Apr 2002
    County Durham
    a car
    Do me a favour and actually do the conversion this time lol
    Content.
  17. #15
    Berkshire
    BMW Beauty
    Thread Starter
    Decided Rubber one's are better due to:
    No more nasty Polybushes.
    ...and my initial feelings anyway...
    p.s. its DEFINATELY getting done in 2 or 3 weeks!
    honest
    Last edited by xx 5id xx; 17-06-2004 at 15:26. Reason: updated link with TomStickland's findings on how crap poly bushes are..!
  18. #16
    Oct 2002
    Corrrrnwaaaaal
    Audi S3
    Quote Originally Posted by xx 5id xx
    honest
    hahahaaaa i've been saying that for months! it will happen soon....................
  19. #17
    Gaz
    Gaz is offline
    Sep 2002
    whether you like it or not its going in soon
  20. #18
    Berkshire
    BMW Beauty
    Thread Starter
    Parts list updated... is everything there??
  21. #19
    Berkshire
    BMW Beauty
    Thread Starter
    Quote Originally Posted by Gary
    only other thing I'd think about doing Sid would be having the oil pump off for a clean and inspection, and new gears if needed - likewise I'd stick a nylon pressure relief valve in if the one in there looks a bit sticky.
    alternatively, just get a new pump.
    Gears.. the F20 gearbox I have is ace!
    Nylon pressure relief valve?? ...for the oil pump?
  22. #20
    Gaz
    Gaz is offline
    Sep 2002
    Gary means the oil pump gears, get in touch with phat sr to see if he took the oil pump off, but it'd be a good idea to have a look ourselves.. list seems fine to me sid..
    Nylon pressure relief valve as Gary says is probably a good idea, tbh sid i reckon as soon as RDS has picked up my old XE bottom end, we should get the block to mine up on the engine stand and all other bits you have.. upto you
    Gaz
  23. #21
    Berkshire
    BMW Beauty
    Thread Starter
    Gaz, yes, take the engine as soon as you can, with all parts, so u can fit it all together. Makes sense!
  24. #22
    Berkshire
    BMW Beauty
    Thread Starter
    CAN SOMEBODY PLEASE CHECK THESE ON THE EPC, or from your own experience, to make sure I got told the right parts!!
    Parts, part numbers & prices (inc. vat) from Vaux ... for engine number 20XE 14019260:
    Prices & parts differ slightly from engines up to #1400+
    Rubber Engine Mounts:
    righthandside EARLY, 90278346, 46.41 / OR righthandside LATER, 90372425, 47.35
    Lefthandside, 90345164, 23.03
    Rear/gearbox, EARLY 90344692, 46.71 / OR LATER, 90447883 47.59
    Exhaust Rubber Mounts, 90280491, 1.10 each x 5
    Handbrake Cable, 90373855, 15.51
    Handbrake Guide Brackets for the Cable:
    Righthandside, 90473889, 1.36
    Lefthandside, 90473888, 1.47
    Heater Matrix Hoses:
    Righthandside Feed, 90572561, 14.69
    Lefthandside Outlet, 90570470, 6.90
    BERU HT Leads set, with High Tension Coil to Dizzy, 90443584, 161.56
    Spark Plugs, single electrode, 91143774, 1.18 each
    Fuel Filter, 25320277, 5.76
    Air Filter, 90486883, 3.76
    Oil Pump, 90325075, 246.75
    Nylon Pressure Relief Valve, 8954566, 6.23
    Suspension:
    Front Wishbones, horizontal bush, 90373263, 11.56 x 2
    Front Wishbones, vertical bush, 90373264, 13.30 x 2
    Front Anti-Roll Bar, 90447867, 0.80p x 2
    Bush above the springs, 90496637, 35.43 x 2 (is this a bump stop?)
    Rear Anti-Roll Bar, 90289369, 3.44 x 2
    Rear Beam/axle bushes, 90305431, 27.73 x 2
    Bush above the springs, 90250393, 9.25 x 2 (is this a bump stop?)
    Fuel Hoses from bulkhead to engine are no longer available!! ...Vaux require them to be pointed out on the EPC drawing, pls.
  25. #23
    Jul 2000
    mate dont pay 160 quid for a set of leads, either get some cheaper ones or some good secondhand ones at this point. and whats with all the rear beam bushes, just put the engine in, all those jobs can be done later mate, dont make work for yourself
    BRB
  26. #24
    MIGWeb Moderator Paul's Avatar
    Midlands
    Most days
    Dude why do you need a new oil pump from Vauxhall?
    Give Autovaux a call.
    Paul
  27. #25
    Berkshire
    BMW Beauty
    Thread Starter
    AUTOVAUX
    Rubber engine mounts for C20XE are:
    Right: 15.50
    Left: 11.50
    Rear: 36.79
    New Oil Pump:
    105.60 ...same manufacturer as Vaux (and normally is 180, but they just change a gasket and get it cheaper)
    VPSCC said it's not worth getting a 2nd hand pump as it could well blow the engine up.
    Any aftermarket, uprated pumps you get for the same price??
