C20LET compression results
Results 1 to 7 of 7
Thread: C20LET compression results
    Jan 2003
    Bromsgrove
    BMW but longs for a Vaux!
    I have just done a compression test on my Cav Turbo.
    These are the results
    Compression with engine at 90', dry test
    No1. 157psi
    No2. 154psi
    No3. 150psi
    No4. 153psi
    Compression with engine at 90', wet test
    No1. 160psi
    No2. 157psi
    No3. 159psi
    No4. 160psi
    No1 being timing belt end.
    Do these sound about right?
    Is it worth putting a new set of rings on?
    Cheers
    Jan 2002
    ayrshire scotland
    like a saint-9points
    Re: C20LET compression results
    looks ok mate. number 3 looks about the worst for wear with a rise of 9psi on the wet test but all the values are very close which is good
    what i cant comment on what the values should actually be lmao. someone else will be able to tell you whether they are in the right ball park or not
    rodgerq
    Northeast Kent
    pretty good results there. barely any rise in the wet test is a good indicator of nice ring seal.
  5. Remove Advertisements
    Jan 2003
    Bromsgrove
    Thread Starter
    The head has gone poures so is is being changed for a fully rebuilt one.
    So i'll leave the rings alone for now then shall i ?
  7. #5
    Oct 2001
    Kent
    the car in front
    How many miles have the rings got on them?
    If it's more than 70K I wouldn'd keep the old ones mate.
  8. #6
    Jan 2003
    Bromsgrove
    Thread Starter
    The car has got 131000 on the clock
  9. #7
    Oct 2001
    Kent
    the car in front
    There you go then.
    When the head's out, check out for a lip at the top of the cylinders. If you've got one, then you'd probably have to go overbore.
    If it's tiny and you don't want to shell out for new set of pistons, just brake the glaze and fit new piston rings.
