Removed cam box last night(without manual) and discovered same bolts secure head. Do i need to change head gasket and skim the head also. Are new bolts required? The head gasket had not blown, problem was cracked box at top pulley caused by bush mechanic and an axe.
Car is 97 Corsa import
