engine codes
442 views 5 replies 2 participants last post by  Dave Hay
#1 ·
i tried seeing what codes my astra would put up after recent problems with abs light.
anyway i turned keys tonight and the abs went out fine. so i just ran some codes and got for ignition on - engine off
12
13
then with engine running i got
12
if my abs was playing up wouldnt a fault have been stored in the computer for when i flashed codes out??
#4 ·
a few years back my ABS light kept coming on when I was driving. When using the paper clip test to flash out the ECU error codes nothing was stored relating to the ABS. I later found out the Corsa ECU doesn't store ABS fault codes.
I just cleaned up all 4 ABS sensors and the rings and the problem went away.
