gearbox compatibility
Results 1 to 2 of 2
Thread: gearbox compatibility
    MIGWeb User andrew_lumb's Avatar
    Apr 2004
    Skoda Octavia vRS
    hi guys,
    i have a nova with a 1.2 engine in it, as standard, which has an f10 (4 speed) gearbox on it..
    soon transplanting a 1.4 mpi into it from a corsa, will the f10 fit that? or do i need to start looking for an f13 (or similar)... also ill need a different linkage if i go 5 speed yeh?
    cheers, andrew
    Feb 2002
    Fareham, Hants.
    C20XE 13S Z20LER Z17DTH
    Re: gearbox compatibility
    I'm pretty certain the F10 came with the 1400 engine anway, it was the 1600 that had the F13.
    Linkage will be ok, but you'll need to cut a bit out of the gearstick under the gaitor that stops the stick moving right for 5th gear. Takes 5 seconds with a hacksaw.
    They're there, in their room.
