I've recently bought a Kenwood head unit - it works fine....except...
The trouble is that the memory gets wiped everytime i turn it on- so i have to enter the security code everytime and set the correct personal user settings e.g. bass, fader etc. I can't use the stereo without having the ignition on.....and its when i switch the ignition off when the memory is wiped.
ignition, battery, and ground wiring is fine- do i need some kind of contact live- e.g. Hazard light switch
You need to swap the 2 live feeds over. Orange and red wires i think.
On the kenwoods loom they probably have bullet connectors on each wire allowing you to swap them over easilly.
..memory as you lose all feed to it when you turn ignition off. When its working properly, there will be a feed to it and a switching feed, the switching feed (from ignition) will turn it on but the permanent feed will keep the memory in the unit.
72.7K members
