cav turbo management light on, whats this fault
Results 1 to 3 of 3
Thread: cav turbo management light on, whats this fault
    Aug 2003
    newcastle
    calibra
    i have a cavalier turbo on a l plate once and a while the engine management light comes on, and when driveing it seems i have no turbo if i thrash it the light goes off and everything is fine
    the code is number 16
    and according to the codes i have its a knock senser 1!!!!!where is this located and does any body know ruffly how much is this?? thanx sorry for the long thread
    my website still quiat join good fun from music to chat www.turbo-freaks.co.uk
    May 2004
    Manchester
    Cav V6
    Re: cav turbo management light on, whats this fault
    Im pretty sure its bolted to the block at the back of the engine just above the plastic pipe from the back of the water pump. Mine's held on by a 13mm bolt with a 2 pin plug going to it. No idea on cost.
    Aug 2003
    newcastle
    calibra
    Thread Starter
    thanx mark found it at last
