C14NZ gearbox problem
Results 1 to 2 of 2
Thread: C14NZ gearbox problem
    Dec 2002
    1996 Opel Astra (1.4) 3dr
    Hi all,
    just wonderin if you guys might know what the problem is:
    pretty much I CANT select 1st or 2nd gear most of the time. It just wont slip in, but i can get all the other gears REV & 3rd to 5th. I took a look at the linkage and it seems a bit loose so took it to a garage, he says that i might need to replace entire gearbox as there is a leak where the linkage meets the top of the gearbox.
    just wonderin if i will have to? and if i do, is it worth it to find a different box? i think that it's an F13 but not sure
    Drive if U'r drivin'
    Dom is offline
    MIGWeb Moderator Dom's Avatar
    Sep 2001
    73bhp MK4 Astra POS
    Re: C14NZ gearbox problem
    Mine does that - 2nd can be a bit of a pig when the gearbox is cold but when its warmed up a bit it sometimes frees up a bit.
    I'm getting used to 1st to 3rd changes now
