does anyone use aquamist water injection
Results 1 to 5 of 5
Thread: does anyone use aquamist water injection
    Dec 2003
    north east
    ASTRA VXR 280bhp
    i plan to buy the above tomorow (ive found a good price) im running phase 3 at 1.5 bar. my charge cooler copes well when moving but stuck in traffic it starts to get a bit warm! the guy who rolling roaded my car suggested water injection. ive no room for an intercooler! what do lets run like with it fitted? also i plan to use a 50/50 alcahol/ water mix! apparenly this raises octane by 10% . my car is 300 brake (proven) what power increase do you think i will see using this kit?
    ASTRA VXR 5000 miles
    full miltek
    stage 2 remap
    ...... now sat on my drive!
    Oct 2001
    Kent
    the car in front
    Re: does anyone use aquamist water injection
    forget the mix that was suggested to you.
    in the summer it will be closer to 100% distilled water
    in the winter there will be some methanol, but as little as you can get away without the bottle freezing
    Do a search for methanol on my site, I have a lot more there
    Dec 2003
    north east
    ASTRA VXR 280bhp
    Thread Starter
    if im fitting this for "charge cooling" rather than "in cylinder cooling" should i have it before my chargecooler, after the cooler or on the plenum cover? also what boost should it be set to come in at (mine peaks at 1.5 bar and runs at 1.15)
    full miltek
    stage 2 remap
  5. Remove Advertisements
    Oct 2001
    Kent
    the car in front
    1. after
    2. around 12psi
  7. #5
    Feb 2002
    Cheadle (Near Stoke)
    Bluefin Focus ST
    Quote Originally Posted by andy16vturbo
    Probably very little difference but it will give more reassurance that you aren't going to get any detonation. As a gauge, when I tried using a bigger jet (1mm up from 6mm) a long time ago it made a 2bhp gain according to the RR but then are they really that accurate?
    I'd try a medium size nozzle (say 6mm) at about 15psi to start off with and see how you go from there.
