20 Xe Wont Start. Help Plse.
Results 1 to 5 of 5
Thread: 20 Xe Wont Start. Help Plse.
    Mar 2004
    Nr Exeter, Devon
    Astra GSI 1991
    Parked my Gsi up last, this morning when I went to start it, ( it had been raining last night) it wouldnt go, the engine is turning over , the starter seems ok, just wont fire up, had this a couple of times before, managed to resolve it Bump starting it..... Any idea's plse would be appreciated... Cheers Matt.
    Northeast Kent
    Re: 20 Xe Wont Start. Help Plse.
    fuel pump relay, dunno where it is on the mk3 though
    Colchester/Brighton
    BMW
    its above the fuse box.. or should be - mine was hanging down along with the ecu lmao
    The Vauxhall Bug; Once Bitten Forever Smitten
  5. Remove Advertisements
    Mar 2004
    Nr Exeter, Devon
    Astra GSI 1991
    Thread Starter
    A big thanks to Oddball, Migweb moderator for correctly diagnosing the problem with my car... changed the relay and car started immediately, found out in the mark 3 the relay is in the front right drivers footwell (thank you haynes). Nice one Oddball, Pm sent. Matt.
  7. #5
    Northeast Kent
    awww you guys
