I've got two Bosch coils here, both in perfect condition
I've got some Ohm measurements across their terminals
Low voltage terminals:
Coil A:0.9Ohm Coil B:1.6
HT to low voltage
Coil A: 7.21 KOhms CoilB: 14.1KOhms
Does anybody know if this alone can indicate a stronger HT voltage on any of the two? Or is the Ohm ratio irrelevant as their windings can be of different diameter/whatever?![]()
- I found my vectra had a completely open circuit plug lead the other day - not even intermittent contact - which explained the very occasional misfire I was getting.. on a turbo lump it would've run like a bag of poo...
lmao
