Leaking Diesel Injectors?
Results 1 to 7 of 7
Thread: Leaking Diesel Injectors?
    Middlesex
    sideways
    So, stopping diesel injectors leaking? Tried some blue instant gasket, and it's sort of working, but one of them is still seeping a bit. They've been done up with a breaker bar, and seem to be leaking where the injector seperates into two peices... They were a nightmare to get out of the head initially, and now they're back in they're weeping and leaking..
    Anyone got any bright ideas at all?
    Brian Sidebotham.
    Oct 2001
    Aberdeenish
    you sure problem aint within the injector?? cavitation?
    if not id put in a thicker gasket as thats what we did on engine test bed at uni.
    seems the only way to stop em leaking is to just keep tightening things up though lol
    Aug 2001
    out there!!!
    modified zafira
    Quote Originally Posted by Brian_S
    lmao they only run around 170ish bar brian (2,000 od psi) not supprised its 'sort of working' lmao
    as for the bright idea.... dont use instannt gasket lmao
  5. Remove Advertisements
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    new ones...
  7. #5
    Dec 2001
    Chelmsford, Essex,
    Astra1.8, Zaf1.8/1.9CDTI
    should they have dowty seals on?
    (Use once wide crinkly copper washers.)
  8. #6
    Feb 2003
    ruislip
    nova 1.8 16v on tbs
    Quote Originally Posted by Mark T
    yeah, but these are leaking on the body, not the union which uses copper washers
  9. #7
    Middlesex
    sideways
    Thread Starter
    Well, the instant gasket is holding out so far...
    Thanks for the advice though Lee. If they start leaking again, then it'll be recon jobbies that'll need to go on there.
    Brian Sidebotham.
