flywheel ringgear on c20xe/f20
Results 1 to 2 of 2
Thread: flywheel ringgear on c20xe/f20
    Mar 2004
    anyone ever had to put a ring gear on a flywheel?
    ive just got mine and i think i have to heat the ring gear to expand it and , when it cools it holds on to the flywheel?
    is this correct?
    The Uberdruck GTE 16V
    jonix :I don't know if I should be rebuilding it or ragging the nuts off it.
    Apr 2003
    Kent UK
    Drives 20xe'd Astra
    Not a job for home unless you have oxy/accetaline bottles as you need to heat the ring till its blue all round then it should just about fall on the flywheel as its expanded so far.
    Be sure to fit it the right way round!!!!
    I supose you could try gas mark 6 in your oven though all the ones I fitted I used the oxy on.
    Make some carrying hooks from wire coathangers to position it over the flywheel as grips may cool it too much.
    Drove: C20xe'd Astra 3 CD, now turned into a c-max diesel!
