head change and now fuel probs
Results 1 to 10 of 10
Thread: head change and now fuel probs
    Dec 2003
    stoke-on-trent
    Vectra GSI
    ok just replaced me cylinder head all went back fine timing spot on to the dot,and ive noticed now im using shedloads of fuel got 75 miles outta 15 quids worth that cant be right! have i missed summat setting back up or ... does it just want a tune cus i changed the head?? and also the cars seems to labour a bit on acceleration as if it sorta deciding whether to go or not temp sensor and crank sensor are both brand new as well as breather mod done etc like a bit of a stutter in 1st and 2nd
    Dec 2003
    england
    Gsi16v
    try reading out the fault codes see if anytying shows up.
    Dec 2003
    stoke-on-trent
    Vectra GSI
    Thread Starter
    upppp
  5. Remove Advertisements
    Sep 2001
    Sheffield
    Mk2 Astra Estate
    is it a bit gutless under 4k rpm?
  7. #5
    Northeast Kent
    how did you time the belt ? not using the crank pulley and the spike on the back plate hopefully.
  8. #6
    Feb 2004
    teesside
    Evo5Tigra
    check colour of plugs to deturmin mixture and look and smell for oil leaks
  9. #7
    Oct 2002
    nr. Uxbridge/Slough
    2.0XE Nova
    Is it worth cutting the backplate spike off? I timed using the mark on the face underneath the pulley. The spike just seems to rip a hole in my hand whenever I'm stroking that part of the engine.
  10. #8
    Dec 2003
    stoke-on-trent
    Vectra GSI
    Thread Starter
    Quote Originally Posted by 0ddball
    yes why,thought that was how its done??!
  11. #9
    Dec 2003
    stoke-on-trent
    Vectra GSI
    Thread Starter
    Quote Originally Posted by jamie_f
    and yes to that too
  12. #10
    Northeast Kent
    Quote Originally Posted by cavgsi170
    well thats what the textbooks say, but its not to be trusted. the crank pulley has a "harmonic balancer" built into it. the crank pulley is made of two parts, the hub and the pulley, and these are joined by a tough rubber ring. the two halves are allowed some movement as part of their tolerance. and hence the outter ring can, in some instances, slip round making the timing marker scrap.
    to time it up correctly, get the cam sprockets on their markers, then use a rod down number 1 spark plug hole (nearest cambelt end) to get piston 1 in the dwell of TDC. an alternative method is to remove the 6 crank pulley bolts, remove the pulley and there is a big fat notch on the rim of the crank sprocket, and a big notch below it in the oil pump. when these two are aligned that is TDC also. fit and tension the belt, check again that the cam sprockets point at their markers when piston 1 is at TDC.
