Have i fooked the head?
Results 1 to 10 of 10
Thread: Have i fooked the head?
    Mar 2003
    On my XE, my cam cover was locked on solid. So gently tapped a flat balanded screwdriver between the gap to release it which worked fine. Till i opened it and saw what i'd done. This is between the cam cover and head. Its only very thin, and im hoping the next gasket will push itself into the gap, or do i need to be a little more worried than that?
    Aug 2001
    Scotland
    diesel pug :(
    should be ok, the gasket goes over either side doesnt it ?
    Mar 2003
    Thread Starter
    I know it goes over the front, dunno about the back. Thats at the front of the engine (thats the exhaust manifold in front).
  5. Remove Advertisements
    Aug 2001
    Scotland
    diesel pug :(
    im just new to this but would say it was fine, and at very worst if it does leak could sort it with chemical metal or something, making sure any doesnt fall/get in to the head.
  7. #5
    Oct 2000
    Portishead
    300ZX TT/Insignia VX-Line
    Should be fine. Could always try a skim of liquid metal and a light sand with some 1400 grit wet n dry.
  8. #6
    Awaiting Email Confirmation
    Jun 2002
    it'll be fine. the gaskets have a H crosssection so will cover it nicely. most rocker gaskets leak anyway if youve got enuff oil in them lmao
  9. #7
    Aug 2001
    Location Location
    Audi
    Yeah it'll be fine.
  10. #8
    Mar 2003
    Thread Starter
    Pheww, thaaaaaaank youuu, had fears of me needing the whol lot smoothed down. I'll rub it down a little bit more so smooth it out and hopefully it'll be fine.
    IF it leaks, i can always take it back off and metal fill it/gasket seal it.
  11. #9
    Aug 2001
    Location Location
    Audi
    Just don't get any bits in the head.
  12. #10
    herts
    BLACK 16v ASTRA GTE
    just leave it youll cause more probs by rubbing it down
    what kind of a t*ss*r puts signatures in .....huh???
