Let Fault Codes.
Results 1 to 9 of 9
Thread: Let Fault Codes.
    Aug 2003
    Barnstaple, N.Devon
    Impreza STI RA
    Let Fault Codes.
    Ecu light started coming on today. But only under hard throttle and around 5000 rpm the car starts to judder. then clears and keeps on pulling.
    I get the following Codes.
    116: Boost Pressure (Above Upper Limit)
    12 Diagnosis Initiated
    13 Lambda Sensor (Open Circuit)
    I have got a Race X Digital Boost Guage fitted, and it showed 8.5 Psi Overboost and 5.3 Psi Normal boost using the standard electronic boost controller.
    I fitted a manual boost controller and set it to 8.5 Psi and the car Goes Like H*ll and has been working ok for a couple of weeks.
    I can only assume the race x Boost Guage is Faulty. hence the low reading on boost. If it is not faulty then what can the problem be?
    Also what is code 12 all about?
    And why do i have code 13 coming up. bearing in mind my ecu light only comes on under hard throttle.
    Cheers Derek
    Many Thanks
    DerekClarke
    (AKA THE M@TRIX)
    Feb 2004
    teesside
    Evo5Tigra
    code 12 means the test is finnished
    Aug 2003
    Barnstaple, N.Devon
    Impreza STI RA
    Thread Starter
    Quote Originally Posted by BarryGTE
    Ok thats that one out of the way thanks.
    Any help with the others would be great.
    Many Thanks
    DerekClarke
    (AKA THE M@TRIX)
  5. Remove Advertisements
    Feb 2004
    teesside
    Evo5Tigra
    sorry m8 cant help with the rest
  7. #5
    Aug 2003
    Barnstaple, N.Devon
    Impreza STI RA
    Thread Starter
    Ok mathe thanks i am sure somone will have some ideas.
    Many Thanks
    DerekClarke
    (AKA THE M@TRIX)
  8. #6
    Jan 2002
    ayrshire scotland
    like a saint-9points
    ok for a start i love the avatar
    ok code 116 is coming on as you have adjusted the boost pressure above the safe limits of the ecu, hence the ecu is cutting boost and that is likely to be the juddering you can feel.
    code 13, well this can mean either that your lambda probe is knackered or it could be a dodgy wire. so check the wiring to the sensor and if its ok then get a new one.
    hth
    rodgerq
  9. #7
    Aug 2003
    Barnstaple, N.Devon
    Impreza STI RA
    Thread Starter
    The boost pressure is within normal Vauxhall settings, as the std boost controller overboost's to 12 Psi and then drops to 8 Psi
    And it does the same when running on the Std electronic controller too. running 5.3 Psi Boost.
    And why would i only get the Lamba sensor code when i get the Boost problem.
    Quote Originally Posted by rodgerq
    hth
    rodgerq
    Many Thanks
    DerekClarke
    (AKA THE M@TRIX)
  10. #8
    Jan 2002
    ayrshire scotland
    dunno mate. i suggest fixing the lambad probe problem first and see of it makes nay difference to the other code.
    try here is you need a new one
    http://www.lambdasensor.com/
    rodgerq
  11. #9
    Aug 2003
    Barnstaple, N.Devon
    Impreza STI RA
    Thread Starter
    Yes but what i am saying is why would i not get the fault with the lamba sensor showing up at any other time. i Reset the ece by disconnecting the Batterey and got no fault codes. drove the car on boost without ecu light coming on and checked no fault codes drove it again floored it and once into 4th under hard throttle about 5k ecu light on again and got all 3 codes up agian.
    Ecu light does not come on with hard throttle in 1St 2nd or third. but does in 4th 5th and 6th.
    Many Thanks
    DerekClarke
    (AKA THE M@TRIX)
