Does anyone make oversize valves for the LET? Has anyone here used them? My best measuring shows a possible 1.5mm (5%) larger inlet valve fitment with at least 1.1mm clearance remaining between them. The exhaust valve is wide-open to uprating. I would use a 5% larger valve there too to maintain E/I flow ratio. Your thoughts?
