Tryin to fit an oil presure gauge to my Calibra Turbo, when i bought the car it had an oil pressure gauge in the centre consul but this was not connected and the volt gauge had been swapped for a boost gauge. I have swapped the boost gauge for a white faced one and relocated it to the drivers air vent, i also bought a tim electric oil pressure gauge in the same style to go with it. I can`t fine a place on the engine to locate the sender, on my old XE the sender went in a hole behind the block, this now contains an oil return pipe form the turbo! The sender unit is a quite bulky unit that comes with any tim elctirc oil pressure gauge:
Does anyone know of a place to locate this sneder? Or is there a plug/cable behind the dash that already as a feed from an existing sender?
Cheers for any help, Mark.
