How to test HES part of loom?
Results 1 to 1 of 1
Thread: How to test HES part of loom?
    DP. is offline
    Nov 2003
    Corsa Gsi
    How to test HES part of wiring loom? HELP PLEASE!!!!
    I think i have a dodgy connection going from the Hall Effect Sensor in my dizzy to the ECU as i have tried 3 dizzies and keep getting the following ECU fault code:
    94 - Hall Effect Sensor - High Voltage
    The HES plug has 3 wires so plan was to use a multimeter to make sure there is no breaks in the wire leading to the ECU plug. Snag is, theres 55 pins on the ECU plug and i dont know which ones are for the HES
    However, I managed to find a PDF file describing each of the pins:
    Can anyone work out which 3 of these pins are for the Hall Effect Sensor (HES) as its not clear.
    I saw the following:
    Pin 31 - voltage to CYL ID (HES):t1 ignition on / running 11v to 13v
    maybe thats one of them.. what about the other 2?
