ok i got the c20xe in the nova and runnin everything is done accept prob with the linkage/clutch.When i took the lump/box from the cav it had a slight prob with the clutch(it felt like it was only lifting up half way making gear changes hard and impossible to put into 1st gear when running) this ment u had to start the engine with it in 1st i thought that if i tightened the clutch cable it would solve the prob - but it hasnt. Any ideas wot the prob is? i cant even get the gears to work like they did in the cav wherever i put the selector and try and pull away it feels like im tryin to pull away in 4th.. Any ideas help please?
