3 Part Driveshafts onto a GTE 16V
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
Thread: 3 Part Driveshafts onto a GTE 16V
    Dec 2001
    Chelmsford, Essex,
    Astra1.8, Zaf1.8/1.9CDTI
    Northeast Kent
    quality experimental project there.
    ive never really understood the purpose of this setup ?? whats the deal with the helper shaft ?
    as far as i see it, it doesnt add up to equal length driveshafts, it just makes unequal length driveshafts, one with a join in the middle ! more stuff to brake !
    Dec 2001
    Chelmsford, Essex,
    Thread Starter
    The theory is, the flexible section of the drivehsafts are the same length, so giving equal torque effects due to the angle of the shafts from the line of the diff.
    Supposed to reduce torque steer.
  5. Remove Advertisements
    Dec 2000
    Certainly made a noticeable difference when I drove Heley's car...
    "The more you turn the wick up the faster it goes" - John Welch
  7. #5
    Dec 2001
    Chelmsford, Essex,
    Thread Starter
    Can't tell at the moment with the GTE.
    I'v3 changed Struts, springs, Tie rod ball joints, and wishbone ball joints.
    Tracking is miles out.
    Steering locks over to the left or right, when turning.
  8. #6
    Northeast Kent
    but i thought some of the torque steer was due to a shorter shaft being easier to turn. having this setup wont change that.
    doesnt steve heleys have a quaiffe slipper ?
  9. #7
    Banned
    Mar 2003
    Turbo Country!!
    A Nissan and a Vaux
    isnt it due to the longer shaft flexing under the force of tourqe ?
  10. #8
    Dec 2001
    Chelmsford, Essex,
    Thread Starter
    I'm sure it's down to the angle of the driveshafts.
    a greater angle from the diff line, will need more force input to give the same force output.
    Having different angles (longer shaft) gives different losses in the driveshaft.
  11. #9
    Admin/show reporter Johnny A's Avatar
    Aug 2001
    Oxford
    Nova Estate
    I have equal length driveshafts on my Nova Turbo, haven't drove it yet but I will see if its any good when I do.
    Vauxhall Nova Estate - Isuzu diesel, EPAS and it's an estate yo!
    Vauxhall Carlton V8 - Lexus 4.0 V8, US Cop car paint and light bar
    I used to be a real jerk but now i'm a people guy
  12. #10
    Dec 2001
    Braintree, Essex
    Mk3 Astra
    Yes, correct. As the CV joint goes through its angular range the efficiency at which it transmits torque varies. The greater the angle, the lower the efficiency. Keeping the driveshafts between CV joints the same length means that they both have the same angular range and therefore the same losses.
    I would like equal length ones on my astra. Are they had to find?
    Cheers
  13. #11
    Northeast Kent
    i assume as they are relatively new addition that you cant get ABS'less versions ?
  14. #12
    Administrator
    Jun 2000
    Hampshire, UK
    Family Car
    they were initally used on the cav gsi oddball i think and that was the only car they were used on, correct me if i am wrong
    and seeing as all gsi's had ABS i would expect your right
    but whats wrong with having the rings and not? qold you not be able to fit a non abs CV joint to this shaft?
    tom
  15. #13
    Northeast Kent
    aaah yeah. i wasnt thinking fourth dimensionally.
  16. #14
    Sep 2001
    Sheffield
    Mk2 Astra Estate
    they are fitted toi cav gsi's, cally 16v's and cav sri's fitted with th xe, thats it.
    i get torque steer in mine, but its not 1 sided, it chenges from side to die at times, so iit does reduce the left wheel from spinng up, they usally spin together
  17. #15
    Aug 2001
    Oxford
    Nova Estate
    and also Cally 2.0 8v's, cos' my Red one has them before I converted it to a 16v
  18. #16
    Northeast Kent
    so whats in that bracket ? is it some kind of hub style bearing ?
  19. #17
    Sep 2001
    Sheffield
    Mk2 Astra Estate
    yea, its just got a bearing in it, thats about it
  20. #18
    Northeast Kent
    mmmm, chink chink chink, the cogs are whiiring away.
  21. #19
    Nov 2002
    glasgow
    pajero2.5td+ zook gv
    I run this set up on my corsa in the dry there is virtualy
    no torque steer and the wet its like jamie_f's both wheels
    spin up and you get a bit of left to right action but its very
    controlable .
    The abs ring just chaps off the cv joint I had to remove mine as they fowled the corsa steering knukle,s'pose this is what the spacer that come with M tech shafts is for.
    blagh blagh blagh
  22. #20
    Dec 2001
    Chelmsford, Essex,
    Thread Starter
    I got these from an Ecotec Calibra.
    My wife's Ecotec Astra doesn't have them, and I'm pretty sure Ecotec Cavaliers don't. (not noticed them anyway)
    There's Ecotec and XE Cally's at my local scrappy, so anyone in essex will find some easily.
    V6s also have them but the bearing bracket is different. (4 bolts instead of 2)
  23. #21
    Dec 2001
    Chelmsford, Essex,
    Thread Starter
  24. #22
    Nov 2000
    Woking, Surrey
    GTE 16v Turbo
    Am I the only one that sort of likes torque steer?
    Contemplating lots of things
    Astra GTE Turbo - Link Now Working
  25. #23
    Northeast Kent
    says he with quaiffe LSD.
  26. #24
    Dec 2001
    Braintree, Essex
    Mk3 Astra
    Which is your local scrappy Mark? How much did you pay for the lot?
    Cheers
  27. #25
    Dec 2001
    Chelmsford, Essex,
    Thread Starter
    Cheers
    NSEC Stock, Stock Autos, and Arrow Salvage.
    Got mine from NSEC, but Stock Autos have the other 2.
    I got several bits for 100, so what they cost me will depend on what the other bits go for.
