Anyone got pictures of 2.0 SEH engine
Results 1 to 11 of 11
Thread: Anyone got pictures of 2.0 SEH engine
    Sep 2003
    Herts
    Has anyone got any pictures on the net of the injection unit of the 2.0 SEH engine the one that went in the 2.0 litre cav SRi. I after one either on or off the car basically the size of it.
    Thanks for reading
    rob
    Oct 2000
    Portishead
    300ZX TT/Insignia VX-Line
    That'll be the same as the Astra GTE 2.0 8v engine then.
    Here is a pic of a standard one....
    May 2002
    Chesham, Bucks
    S14
    err.... thats not standard.
    its got a halfords battery.
    ///DGOAI
  5. Remove Advertisements
    Sep 2003
    Johannesburg
    My 1999 Mk3 ASTRA 200iSE looks slightly different
    http://forum.opelownersclubwc.co.za/...hp?pic_id=2226
    A few things are moved about. plus it has the original yellow oil cap
  7. #5
    Apr 2002
    Essex - Colchester
    M135i
    the 1999 mk3 would not have an SEH.
    what exactly do you mean by "injection unit"?
  8. #6
    Sep 2003
    Johannesburg
    It would if it came from South Africa
  9. #7
    Apr 2002
    Essex - Colchester
    M135i
    fair enough
  10. #8
    Sep 2003
    Herts
    Thread Starter
    Thanks for the pic. yer I just want to compare sizes between the 16v and the 8v complete manifold/plenem chamber casting as I am using the XE engine in a kit car and have not got the space for the oringinal one between the engine and bulkhead. Thinking along the lines of modiflying the 8v sri one to suit the 16v head if its slightly less bulky. Can't afford throttle bodies
  11. #9
    Oct 2000
    Portishead
    For more info on modifying the 8v, including using 16v bottom end + vertually everything you could possibly want to know about the 20SEH engine check out this site.....
    http://www.tomstickland.co.uk
    You'll not find a more usefull site.
  12. #10
    May 2002
    Chesham, Bucks
    S14
    If you can't afford throttle bodies, get some twin dcoe 45's.
    ///DGOAI
  13. #11
    Sep 2003
    Herts
    Thread Starter
    Yer I did look into carbs as that is definiatly the easiest way to go I was told when using the XE I can run a dissy from an astra 1.6. I might still go this route but I would prefere better fuel economy and cold start fueling
