hi im fitting a magnex exhaust to my gte i guess i can fit this straight to my original down pipe put problems arise with the bolts needed from the downpipe where it joins the main run under the car . i think the original bolts are some sort of spring incorperate bolts to stop vibration traveling the length of the exhaust. ideally the bolts need to be longer and a larger size to cope with this any ideals thanks
