Let Ecu
431 views 4 replies 4 participants last post by  Lee Smiley
#1 ·
If i drive steady (ha) the car is fine. It judders a bit when cold but i know i need new plugs.
But when i boot it there seems to be a clicking noise, like a relay, coming from the ECU. It seems to do in more under load like when im in 6th down the motorway and put the toe down it goes mental and a few times the car has cut out.
If its been thrashed and i let off the throttle it does it a few times then aswell and then going over bumps or pot holes it does it.
Any ideas please
Startin to p155 me off:mad: :mad:
#3 ·
coming from the ECU???? how sure or ecu area?? as said could be fuel pump relay in need of replacement.
there are no relay's as such with ecu just check loom is connected correctly.
