Astra G - Headlight condensation
7K views 12 replies 5 participants last post by  BYRONGSi
#1 ·
As above really...this weather is playing havoc with both my headlights and rear clusters, which in turn leaves condensation inside the casings.:(
I know that it is a common problem on the astra g, but what would you recommend to 'seal' them once I have dried them out?
I want to sort this once and for all, as I cant stand them looking like they do at the moment!:mad:
Any suggestions?:confused:
#4 ·
I have dried out all the moist that was in there, and greased all the seals over..
I put them back onto the car and witihn 10 minutes of driving they were worse than before i had taken them off!:mad:
Any one have any solutions to this common problem?
should i be blowing hot air into the bulb sockets whilst fitting them back onto the car? I am out of ideas:rolleyes:
A:beer: , goes to the person that offers a solution that works and avoids me having to pay out for tinted headlights and irmscher smoked rear ones:(
#5 ·
i got the same problem on my punto lights i only fitted them on saturday i was told to put grease on the seals but dont sound like that works either?:(
#6 ·
headlights tend to be sealed units, so my only thinknig is that the moisture is getting in at the bulbs....
whatever the problem is - its frustrating as hell, and makes the car look cack. Its amazing how something like this makes me dislike my car so much.:rolleyes:
#12 ·
No way are headlights sealed. Not only, as you say, is there effectively a gap where the bulbs and associated wiring goes in, there'll also be a drain hole somewhere.
If you're super confident, take the units out and completely seal them, including the drains. Then grease up the bulb or wiring grommets. See how that goes.
