Hi guys, my fuel pump fuse keeps blowing, well, its done it twice now and its really ****ing me off. its an fse pump and its rated to three hundred horsepower. the engines on mbe management and the relays are fine. i was wondering if the pressure regulator( its set to 50 psi) is causing the pump to overload. any suggestions would be greatly appreciated. cheers
