xe-want more power
Results 1 to 6 of 6
Thread: xe-want more power
    Sep 2003
    middlesex
    cavalier gsi2000
    xe-want more power
    my cav gsi needs a bit more poke,ive got a budget of 1500,can anyone head me in the right direction.the engine is totally std and done 100k.
    May 2002
    Rainham, Kent, UK
    Corsa VXR
    1) NOS (600+)
    2) throttle bodies (1500-2000 for full set up and RR)
    Other than that, go and get a turbo. Converting a c20xe to a c20let is too time consuming and expensive. I've seen some c20let's go for 1000 (engine), so you could do an engine swap. Or ditch your old car and buy a cav/calibra turbo instead, there are few going for 1500 anyway.
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
    Re: xe-want more power
    goto for sale section and buy TFS engine and throttles for 1600
  5. Remove Advertisements
    Mar 2001
    Torquay
    Audi A3 07 170 DSG
  7. #5
    Sep 2002
    Here
    04 TT 225
    Get the injectors cleaned.
    New plugs n leads
    bigger brakes
    Mod the air box
    K&N Panel filter
    Cams
    UNichip
  8. #6
    Sep 2003
    middlesex
    cavalier gsi2000
    Thread Starter
    did a search-apparently you can get a group n kit from sbd which gives alot more power/torque than chips,and gets rid of the afm.anyone know how much this is?they also do a type a manifold for my cav gsi-is this a good set up.
