timing belt change on c20xe
Results 1 to 4 of 4
Thread: timing belt change on c20xe
    May 2003
    Southend
    Nova Turbo
    i want to change the timing belt on my c20xe before i drop it in my nova, is it hard to do - never done one before?
    Aug 2003
    derbyshire
    Nova 2L 16v
    doing it before should be a peice of ****.
    i had to do it when it was in the car, and there aint much room when its in a nova.
    the only reallly probelms i had was with the bottom pulley bolts being rounded (easy to sort when its not in a car) and actually having to take the engine off the mounts to get the bottom pully off. part from that easy job
    GUTTED, my novas gone :(
    May 2001
    52.26320 -0.81374
    2.0 16v Astra GTE
    Is it an early C20XE or a later, the early has two steel rollers and the later has a self tensioner and nylon rollers.
    If it is a later one I recommend getting steel replacment rollers from Autovaux.
    Also change the water pump too especially if the engine has been stood for any time with no anti-freeze in.
    Incidently if anyone wants a water-pump for a later C20XE or ecotec I have one brand new GM parts supplied for sale... 20 + P&P
    Veni,Vidi,Scubi
  5. Remove Advertisements
    May 2003
    Southend
    Nova Turbo
    Thread Starter
    im not sure how to tell what one it is... its out of a cav gsi Hreg 1991
