K&N Air Filter for Vauxhaul Nova 1.3sr & 1.4sr, Pierburg 2e3 or Weber carburettor
K&N Air Filter for Vauxhaul Nova sr, Pierburg 2e3 or Weber carburettor 56-9159 | eBay
A K&N Air Filter (product code 56-9159), this item is for the Pierburg 2e3 carburettors which were found on many vauxhalls from the 80's to the early 90's. This particular item is for Vauxhaul Nova 1.3sr but as mentioned this will 'bolt on' straight away to number of engines such as 12ST, 13SB, 14NV. With adaptor plates these can be fitted to all Pierburg 2e3 carbs found on other European cars and also Weber 32/34 DMTL.
I bought this way back in 2001 my uni days, from what I remember it was only in my 1300sr for 6 to 9 months as the K&N filter rubbed against the bonnet after I replaced the Pierburg 2e3with an Weber 32/34 DMTL carb and adaptor plate on varaijet manifold. To fit with the minimal contact I had to remove one of the bolt & stud and use one slimmer bolt on the other, sadly I can not remember where I placed the stud & bolt.
Here is a link to the manufactures website 56-9159 - K&N Custom Assemblies, Custom Racing Assembly direct from K&N
Bidding starting at 9.99 with no reserve.
