C20LET Calibra Turbo enlarged SFS boost silicone hose (THS34) New Samco Red | eBay
This kit will replace the original hazardous restrictive turbo boost intercooler hose, I believe Vauxhall designed the C20LET with 40mm Internal Diameter (I.D) bore pipework to achieve extreme Low End Torque and to eliminate turbo lag. Being oem replacement this kit is as big as it gets and available on the market with the likes of Samco, being almost 20% bigger in diameter this will have an improvement on the engine. Personally I will remove the oem black metal pipe for 49mm bore to maximise from the bigger 90* bend hose.
1. Intercooler to Tophat hose (part number THS34.1) = I.D 47mm to 46mm
2. Turbo to Air Mass Meter hose (part number THS34.2) = I.D 56mm to 78mm
3. 2x Turbo to metal pipe, metal pipe to intercooler hose (part number THS34.3) = I.D 49mm.
more information can be found at the manufactures website below
SFS Performance - Silicone Hoses
hey guys this is up for grabs, the starting the bid is £25 with no reserve.
