On Ebay atm
Cavalier 4x4 GSI 2000
Floor Plan with Tunneling £100
Front and rear Suspension £200 (with hubs shafts front struts) F20 4x4 and rear transferbox included
40mm Gmax lowering Kit £60
Cavalier GSI 2000 Body Kit with fogs intact £90.00 Includes Irmy rear boot and all covers and caps.
4 X Cavalier GSI Doors in Spectral Blue £50 ono (no door cards , Full electric )
Cavalier GSI 2000 Dashboard £80.00 VVGC
Cavalier GSI 2000 Saloon rear Glass setup £ 40.00 Collection only on this as Glass
C20let AFM ,Loom (TPS Cut but this is the only wire cut can solder it back on for you) and Distributor and coil pack , various sensors Like Amal Valve £150.00
C20let ECU opened to check whats inside ( Phase 2 Chip with power Switch wiring) £60.00 untested as running on megasquirt (came with the loom)
