A couple of bits and bobs on eBay that someone might find a home for!
Recently removed my LC-1 eBay - The UK's Online Marketplace
Innovate's LC-1 is perfect for permanent car installs. Will hook up to one of their MTS dash board gauges via a digital serial connection, or thanks to two separately programable analogue connections will feed any gauge accepting a 0 to 5 Volt or lower signal - I used it with a Race Technology Dash 2, the second analogue out is perfect for connecting to your ecu. It will either simulate an ordinary narrow band Lambda sensor - perfect if you have a car with a CAT for emissions purposes, or it can be set to give a second wideband output that your ecu can use for closed loop mapping. (Sometimes called adaptive mapping, or self learning)
If you click on my other items for sale link, I've also got a C20XE metal oil filler cap on their; found it the other day, left over from before I went dry sump, the cam cover filler is permanently sealed up and powdercoated over now, so the cap's no use to me anymore.
No reserve on either, thanks for looking.
