Tech2 equipped garages around the Lincolnshire,norfolk,cambridge areas
Friends Clutch Actuator has gone on their easytronic Astra H, I can get ecutesting ltd to refurbish it, but I'm obviously stuck at the point of reinstalling it as TIS details state it needs to be bleed and have the parameters set by tech2 software/system.
If this is generally the case and there are no easier/cheaper ways around the problem, does anyone know of any decent garages around the south Lincolnshire area, or even over the boarders to Cambridgeshire or Norfolk ?
VX main wants to charge £600 minimum with no grantee's of fixing the problem by the way. Just thoroughly checking to see if there are slightly cheaper ways of doing this ( IE by me removing it and sending it off to ecutesting ltd, then refit it but have it trailered to wherever has tech 2 and only need to pay for the bleed and set up, if that makes sense ? ).
Cheers !
Mig Club Member
Re: Tech2 equipped garages around the Lincolnshire,norfolk,cambridge areas
Any one with the latest version of op com should be able to help you out m8
Fenns Vauxhall specalists in Kings Lynn have tech 2.
PS. No relation unfortunatly lmao
Thanks very much for the input ! I shall pass the info on to the owners, I think they plan to sell the car as soon as its fixed which.....is fair enough.
