Replacing Bathroom Floor - Days 1-7.
Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 101 to 125 of 143
Thread: Replacing Bathroom Floor - Days 1-7.
  1. #101
    Jan 2010
    Fife
    vec c sri vvt
    Re: Replacing Bathroom Floor - Days 1-7.
    Good stuff dan, just be carefull in taking boiler casings off as some models come with sealing washers that must be replaced.
    "Cnt stop cleaning it!"
    MSG
    MSG is offline
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Quote Originally Posted by couped View Post
    MSG and JO4NNY8...... a bath trap is 1" 1/2 allowing for 1"1/2 waste pipe connections and fittings, a sink waste is 1"1/4. Two different sizes and in jonny8 defence the pic hes posted is that of acorrect 1"1/2 bath trap which you do get various types, and msg theres no way you can convert a 1"1/4 sink waste to fit a bath!.. dnt tell me your a plumber because your giving us honest worker in the game a bad name!
    I fit at least 3 bathrooms a month and have only ever used in my 17yrs experience silicone on the steel parts when putting a trap together,the sealing washer is there for a reason, in the 8 years ive owned my own buisness ive never had a comeback or leak.
    Sorry Couped , I couldn't tell if it was 1 1/4" or 1 1/2" BSP outlet purely looking at the picture, both look similar unless placed against each other or some scale in the back ground, only then i could have easily defined the difference in the sizes, However most bath traps commonly available are the centre screw type, what the are also know as the combined drain type. If you check Wickes, they only stock the centre screw type unless I don't know if other stores like B&Q might do the metal ones with a large nut in 1 1/2" BSP. Hence almost all traps that I have come across in my life have all been the single screw type. I have seen some larger ones used in bigger kitchens using large stainless steel bowls, where I have seen these in use. And to say the least almost everyone that I saw only because it had a leak, and I have fixed many such leaks basically using silicone sealant, but the flat i was talking about was a complete nightmare.
    The acess to the underside was very restricted as I could just get squeesed betwen the tub and the loo pan, so it was a real pain in thge neck, however its now all sorted. thanks any ways.
    God does exist, to meet him, the price is quite high, he lives in 9th Dimension, to get there only your Soul can travel there at faster than the speed of light, first you will have to shed your physical body, then just hope you have got on the right highway to heaven.
  4. #103
    Jan 2010
    Fife
    vec c sri vvt
    Quote Originally Posted by MSG View Post
    What about a pop up waste?......a click waste?.... totaly different, in the pic posted you can clearly tell its a sink waste due to the size of the overflow outlet above the threads!
  5. #104
    Jan 2010
    Fife
    vec c sri vvt
    No needto say sorry buddy, just feel the thread makes you look an arse because you got some wire crossed and didnt fully understand what you were talking about.
    Simple really-LEAVE THE PLUMBING TO THE PLUMBERS!..LOL
  6. #105
    MSG
    MSG is offline
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    sure I did not get any wires crossed, because someone brought in the outlet that I wasn't even talking about in the first place,
    So when I was discussing how I stopped a leak on my shallow plastic trap with a centre screw, why then bring in the metal 1 1/2" BSP outlet and then try to explain to me how easy it is to seal that one.
  7. #106
    Funk that, this thread shows that with a bit of brains that anyone can do it.
    Performance Vauxhall Show - HERE Please click for more information.
    VBOA at Billing - HERE Please click for more information.
  8. #107
    Gagged
    May 2005
    central scotland
    astra G coupe c20let
    . If you check Wickes, they only stock the centre screw type unless I don't know if other stores like B&Q might do the metal ones with a large nut in 1 1/2" BSP. The acess to the underside was very restricted as I could just get squeesed betwen the tub and the loo pan, so it was a real pain in thge neck, however its now all sorted. thanks any ways.
    And you wonder why you always have problems. theres your problem right there. why do you think you have plumbers merchants. the pain in the neck is why plumbers make good money, that and touching your waste pipes full of your sh*te
    Racing is life, anything before or after is just waiting but its better to be late in this world than early in the next
  9. #108
    Jan 2007
    Co. Meath, Ireland
    Mk2 Cav LET
    Until something goes wrong
  10. #109
    Quote Originally Posted by Frisco View Post
    Most that can go wrong is a leak..
  11. #110
    Jan 2010
    Fife
    vec c sri vvt
    Yea, on a boiler casing which is sealed for a reason, mind you it wouldnt take long until nod land kicked in! and the old bill were knocking the door down a fortnight later because the neigbours complained about the smell of your dcomposed body rotting away.
    That is gas side of things, but plumbing wise the diy enthusiast will have no prob.
  12. #111
    Jan 2010
    Fife
    vec c sri vvt
    Quote Originally Posted by anniman1 View Post
    The only plumbers that make a good living are those in london and bigger citys, mainly because there robbing twats!.lol... My mate charged customers £300 for coming out and switching there water main off during the xmas period, hes based in london. Where is i run around like a headless chicken charging £60 on xmas eve and fixing the leak in the process.... mind you that customer is still due!..
    For the work dan done and what he needed done i would have set him back at least £280-300 max inc fittings and materials, the bath and ware would be customer supplied.
  13. #112
    MSG
    MSG is offline
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Just get a CO detecter if anyone is undually worried about CO fumes leaking from their boiler, a good digital readout one cost less than 16 quid made by Kidde Model No 900-0260, and works brilliant as it can detect CO levels right down to 11 parts per Million.
  14. #113
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    I'm not worried about CO, cos I know the flue is not blocked, in good condition and the fan works a treat!
    They're there, in their room.
  15. #114
    MIGClub Member jamied's Avatar
    May 2003
    northampton
    loads of things
    crist i have fitted about 6 boilers over the past 8 months with no problems and all were tested by my plumber mate after fitting with no remedial work. Dan when was you thinking of tiling..might have something of interest for you.
  16. #115
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Er, years probably!
  17. #116
    Jan 2007
    Co. Meath, Ireland
    Mk2 Cav LET
    For most things diy is worth a bash.
    All im saying is be careful when it comes to boilers, as couped said earlier on some boilers the front cover is part of the combustion chamber so if its not resealed correctly you can have serious trouble.
    The flue doesn't have to be blocked for CO to be a problem and its still illegal to open them even if its your house. Nobody will know until someone gets hurt/killed (which is a very real possibility)
  18. #117
    May 2010
    Newcastle
    Astra C20LET
    Hey Dan, any other plans for the bathroom? I.e. are you re-tiling it etc?
  19. #118
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Might do eventually but as said the whole room will need re-plastering, so will leave it for a year or so yet.
  20. #119
    Gagged
    Jan 2005
    The Internet.
    Mods round the bend...
    I don't care what has been said, MSG is GOD!
  21. #120
    MSG
    MSG is offline
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    I am no God, come on Wayne! but I have developed immunity to ugly remarks and abuse. I can't help if some people have got more testostrone than intelligence.lmao
  22. #121
    Dec 2001
    Southampton/Reading
    No longer The Pheonix
    And if that wasn't an open invite for a cyber drop kick i dont know what is lmao
  23. #122
    MSG
    MSG is offline
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    Ouch! that flippin hurt now!!lmao
  24. #123
    Ed
    Ed is offline
    South Croydon/Surrey
    Merc W201 190 & W124 300
    Yeah exactly. I completely renovated my place, having had no prior experience. I just read a lot and asked advice from mates in the trade. I did:
    Total rewire from consumer unit up
    Fitted boiler
    Fitted Central Heating
    New Kitchen
    New Bathroom
    Al cables and pipes hidden, and this is in a place with concrete floors, so wasn't easy.
    Only labour I paid for was Gas Safe guy who connected gas to my boiler, and the carpet fitter.
  25. #124
    Mar 2010
    Stockport, Cheshire
    Golf Mk4, AstraVan
    What about the rules that came in to force in 2005 about not doing wiring unless you are qualified?
    If you come to sell it or there is a fire and insurance claim, won't there be a few questions to answer? I'm not being funny or anything, as I do my own wiring (did the whole of my last house - pre 2005), but have been put off a bit by the legislation.
    “Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
  26. #125
    Ed
    Ed is offline
    My mate's dad is a qualified electrician and told me exactly what to do. I did exactly as he said and he tested it afterwards and issued me the certificate. Job done.
