Performance thinking
Results 1 to 11 of 11
Thread: Performance thinking
    Aug 2008
    Perth ecosse
    Red Let
    Im thinking about corsa c conversions and would like to ask for some opinion as to what would be easier or bring more advantages between c and zlet/h
    my main question is could the c20let match the performance of a z20leh?
    and what gearbox options are available?
    This is based on fully rebuilding the let i currently have to go in my corsa c sri
    Aug 2008
    Perth ecosse
    Red Let
    Re: Performance thinking
    Ive been trying to find some threads on the wiring but no luck so far..
    Jun 2012
    I would have though a zlet would be a easier conversion as far as clocks and that go but not sure I it runs a can bus system like a zlet or not
    Aug 2008
    Perth ecosse
    Red Let
    its easy enough for me in respect i have the parts, just unsure how well these work together and if there would be more potential using a newer engine.
    Personally i think it would be a good combo
    would i still need to keep the cars original ecu in place? or could i combine aftermarket managment into the car?
    Aug 2008
    Perth ecosse
    Red Let
    How do you get around setting up the clutch for these conversions?
    As its hydraulic on the c so would i need to find a box with the same clutch?
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    You can use a hydraulic release bearing from, I think, a Vectra B F18 or similar.
    I think a ZLET in a Corsa C is easier due to the fly by wire and you can even reflash the car ECU to run the new engine or something.
    They're there, in their room.
    Aug 2008
    Perth ecosse
    Red Let
    So i could keep the f28 gearbox and use the bearing to operate the clutch?
    Aug 2008
    Perth ecosse
    Red Let
    What about mounts and wiring it in? can anyone point me to a good spot for info as i see its been done before?
    You can use Corsa C Derv mounts and shafts.
    Performance Vauxhall Show - HERE Please click for more information.
    VBOA at Billing - HERE Please click for more information.
    Aug 2008
    Perth ecosse
    Red Let
    Cheers benn, will the bigblock equal length driveshafts i have be of any use?
    theres a good thread from 2007 here on one, got as far as mounting the block by the looks of it.
    As for mounting i dont really like the idea of cutting a hole in the timing assembly cover
    Id Zlet it. Everything will bolt in then. It's what i wanna do.
