Right so basicly I'm seriously fed up with seeing my project car under an inch of dust and Land Rover parts in my workshop.
For those of you that know the car your clearly very oldfor everyone else its a MK3 Astra 3 door hatch originally a 1.4 merit.
Current state of play is the car is a completly stripped shell and has been painted and had a 12 point cage welded in.
Parts wise I have a B204L Saab turbo engine, F28 with LSD, 5 stud hubs, 330mm front discs with Wilwood 4 pots and uprated rear discs and pads, equal length drive shaft, two bucket seats, glass, subframe, rear beam and all panels.
Question is now where to start? I need to try and break the build up into sections as I think this is the best way to make progress.
I'm thinking getting it to a rolling shell would be a good start. For this I'm gonna need suspension, wishbones, steering rack, track rods and bushes.
Cars being built as a road legal track car so suspension wise I was thinking Gaz Coilovers, but not sure on which setup to go for as the car has the heavier engine and mk2 Escort rear turrets.
Help and inspiration required!
Chris
