crash corsa need info?
Results 1 to 18 of 18
Thread: crash corsa need info?
    Apr 2010
    cheshunt
    corsa b
    i crash my corsa on a roundabout and bent the hup got that fixed but both wheels still aint straight the man says its the lower arm or shocks or steering rack but 1/100 chance that i bent the chassi does anyone no what it could be ?
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Re: crash corsa need info?
    Could of easily bent a lower arm or the chassis.
    Lower arms on Corsas are plated so I'd expect the shock to of bent the chassis personally. Just get under it and take a look
    Jul 2010
    widnes
    combo
    the lower arms should bend before damaging the chassis, as there designed to take the damage as not to bend the chassis. but also depeneds on the impact of the crash, angle, speed ect
    Apr 2010
    cheshunt
    corsa b
    turning right slightly hard whats the chances of it being the chassis?
    Jul 2010
    widnes
    combo
    as said depends on the position it was hit, most chance it will be lower arm or steering rack bent or just tracking get pics up if u can
    Apr 2010
    cheshunt
    corsa b
    wel got the lower arm today aint on yet but find out tomoz
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Crikey man !
    Get a jack, look under the car, chassis rails should look identical either side, if one doesn't then you have bent the chassis.
    A guy locally did something in his nova a few weeks back and that had bent the chassis, car has done 30k as well so it was far from a rotten pig, Corsas do run plated TCA's which does mean there is more of a chance that it would bend the chassis with that sort of impact, its a risk you take with those sort of arms.
    Apr 2010
    cheshunt
    corsa b
    had the arm and hub done and they said the chassis is fine and its the aintroll ball bent? that right?
    MIGWeb Moderator
    Midlands
    Nowt
    aintroll? Whats that?
    You mean anti roll bar? If bent, change it
    We cannot tell from here
    Apr 2010
    cheshunt
    corsa b
    funny one
    MIGWeb Moderator
    Midlands
    Nowt
    What is?
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    I presume you have had it tracked up since all this work ?
    Apr 2010
    cheshunt
    corsa b
    putting the roll ball on then tracked
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    you can mess up your tracking by simply unbolting and then refitting a suspension strut, main things to look at after the accident is for anything that looks bent, if it looks fine then just chuck it in for tracking.
    9/10 nothing's really damaged just tweaked out.
    Apr 2010
    cheshunt
    corsa b
    roll bar going on later but now it pullin to hard to the right just to be the roll bar any ideads?
    Jul 2006
    Sutton Coldfield
    Fiesta ZS, Clio 172
    so you haven't tracked it up and you expect a miracle?
    replacing parts will not put your tracking straight.
    Apr 2010
    cheshunt
    corsa b
    i no but the roll bar is bent so gonna need changing and then we doig tracking
    Oct 2003
    Nr St Ives, Cambs
    Pug 309 Cosworth
    Your original post :
    Surely getting it tracked up would of been the first thing to of done.
