Anyone used Mr Clutch?
Results 1 to 14 of 14
Thread: Anyone used Mr Clutch?
    Sep 2007
    Sussex
    My 2.6 needs a clutch and slave and Mr Clutch are cheaper then the rest by quite a margin.
    Anyone used 'em.....good? bad?
    Sep 2004
    East Ayrshire
    C:, D:
    Re: Anyone used Mr Clutch?
    Mr Clutch does it again! - The FIAT Forum
    Its a two year old thread, it follows the trend of other stuff that can be found on google though..
    Sandwiches and laminated printouts!? You widnae get this at AVA...
    Sep 2007
    Sussex
    Quote Originally Posted by Mark_F View Post
    Thanks mate!
    Jan 2009
    Wiltshire
    Corsa TD, DC2 ITR.
    I had a gearbox replaced not long after buying my old RS Turbo under warrenty, and after about a week my box nearly fell out i.e it only had one loose bolt holding it on
    But I think it all depends on the fitter.
    Sep 2004
    Bristol
    stage 5 saab 9-3 se sport
    yes if your lucky you may get 2 bolts! one of wich will be cross threaded
    Xbox Live! = DEATHS UNCLE
    The following words in your search query were ignored because they are too common words: 9000 problem
    Jan 2009
    Wiltshire
    Corsa TD, DC2 ITR.
    Quote Originally Posted by Jasovanooo View Post
    lmao
    Nov 2009
    Ruskington, Lincolnshire
    Corsa B X20XEV
    one of my mates brough a saxo and it had a clutch put in at mr clutch 3 weeks before he got it and was still under waranty when it went, they wouldnt replace it so i ended up doing it, when i got the clutch out it turned out the clutch was a cheap re manufactured unit, that will be why it didnt last 5 minutes, plus none of the gearbox bolts were tight!!
    Dec 2001
    Southampton/Reading
    No longer The Pheonix
    My sister in law had a clutch done by them on her Renault Megane and they forgot to put gear oil back in. Subsequently her box wasn't too well after driving home like it and then about for two days
    Sep 2007
    Sussex
    Drat! Just gotta find somewhere else then that'll fit one this side of Christmas
    Oct 2002
    South London/ Surrey
    A4 sport avant Clio172
    Depends where you go. My mate takes his cars to his local one as it works out cheaper them doing it than him. but he knows them well! Oh and he supplies the bits!
    I sent my sisters boyfriend to have his done at one I trust. That car has been fine too! I have heard/seen horror stories though
    www.shonkyopels.de
    Nov 2000
    Reading Berkshire
    Vectra GSi & GTE 16V
    Mr Clutch? Do you value your car dude?
    Dont go there, EVER!!
    May 2001
    South Wales
    Nippy Cav Turbo
    i went to mr clutch cause i was desperate to get a clutched changed asap (provided clutch) and to be fair they did it fine bar when i drove off i was missing 6th gear lmao so went back and explained and they didnt realise i had 6 gears lmao..soon sorted it and off i trundled with a tidy £220 bill. this was what 4 years ago mind so bugger knows what they like now!
    Oct 2008
    London
    Calibre
    I know of a Lotus Carlton that has been sitting for the last 5 years because of MR. Clutch. Would I take my Cav turbo 4x4 there. Nope I'd rather burn it.
    May 2001
    South of France
    vectra sri v6
    The kwikfit of the clutch world - it might go ok, and then again, it might not.
    Oh, and if part way through the job the grease monkey pops into the waiting room and says
    "its apart now and your flywheel is quite scored and should really be skimmed. its £30 extra, but Id recommend it for the long life of the new clutch"
    you should then say "can I have a look at your lathe?"
    He will then say "what lathe?"
    You should then say "How the **** are you planning on skimming my flywheel without a lathe you fud?"
