What Engine Code Mk4 Astra Coupe 1.8 16v
Results 1 to 8 of 8
Thread: What Engine Code Mk4 Astra Coupe 1.8 16v
    Apr 2005
    swansea
    MK4 ASTRA VAN,V
    Hi ive got a w plate 2000 model 1.8 16v bertone astra coupe with a duff engine looking for a re-placement but need to know what engine code as i cant make it out on the block.
    Is it an x18xe-1 or an z18xe,i know it aint an x18xe.
    Thanks in advance
    That's bloody brilliant that is!
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    Re: What Engine Code Mk4 Astra Coupe 1.8 16v
    Probably Z18XE
    3.0 V6 CDTI Vectra SRI
    You can't get thicker than a Kwik-fit fitter.
    Jul 2008
    in a house
    lots
    its a z18xe same as mine mate
    Apr 2005
    swansea
    MK4 ASTRA VAN,V
    Ok just what i thought
    Will a x18xe1 fit,direct replacement as i can pick 1 of these up for a fraction of the cost of the other
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    No, the reason being is the Z18XE is fly by wire where as the X18XE1 is cable the Z18 also has an extra 10 bhp on top. So unless you fancy transferring the whole of the electronics side over it would be easier to stop with the Z18XE.
    Actually maybe you could swap the the bare engine over and use all the Z18XE ancillaries on an X18XE1 lump...
    Apr 2005
    swansea
    MK4 ASTRA VAN,V
    Well mine is cable not fly by wire and the cat is under the car not on the down pipe so must be x18xe1 if im right in what im saying?
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    yep in which case its an X18XE1
    i though all the coupes were Z18XE
    Apr 2005
    swansea
    MK4 ASTRA VAN,V
    It is the first of them matw being on a w plate so that might be the reason why
