need a buyers guide to the mk4 astra sri.
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 32
Thread: need a buyers guide to the mk4 astra sri.
    May 2005
    york
    bmw e46 323ci
    Exclamation need a buyers guide to the mk4 astra sri.
    What to look out for, what spec and 0-60 of the 1.8, 20l, and 2.2. What is the handling like, and what goes wrong with them, cheers.
    Old school ISCOOL!
    May 2005
    york
    bmw e46 323ci
    any1
    Old school ISCOOL!
    Bishops Stortford
    2 seat 2.2 vxl
    its been covered about a million times recently
    http://slindborg.hostei.com/ Gearbox calc, Top speed, compression ratio, engine capacity, 1.4 tuning guide, Wheel offset calculator
    Fixed broken gearbox calc :)
    May 2005
    york
    bmw e46 323ci
    Quote Originally Posted by cambridge View Post
    yes thanks for that! what a great help! Mig at its best again i see.
    Last time i did a search i couldn't find anything! still at least its been covered a million times already
    Old school ISCOOL!
    MIGClub Member Lugy's Avatar
    Sep 2005
    Midlothian, Scotland
    Cav SRi/BMW E30
    A bit OT but it could help in future, how about a section where people can write and upload buyers guides for cars. Not like it would never get used. And perhaps when people find niggles then they can be added.
    May 2005
    york
    bmw e46 323ci
    Quote Originally Posted by lugy View Post
    that sounds like a brillient idea! defo get loads of views. any mods around?
    Old school ISCOOL!
    Sep 2005
    Cav SRi/BMW E30
    Quote Originally Posted by Vauxfan View Post
    Unfortunately, some folk may not see this as good a thing as us 'cause its too "easy" and noobish
    Certainly gets my vote though!
    May 2005
    york
    bmw e46 323ci
    well they are just dipshiits then!
    Old school ISCOOL!
    Nov 2000
    North Ayrshire
    06 Fabia vRS
    so what do you suggest we do?
    Hold a gun to Migweb users and force them to reply or you learn to use the search and its results better?
    May 2005
    york
    bmw e46 323ci
    Quote Originally Posted by Big Col View Post
    No just a simple point at the right thread post! I had a look, didn't really find anything! But whats the point in posting if you have nothing but sarcasm?
    Old school ISCOOL!
    May 2005
    york
    bmw e46 323ci
    just found this in tv, does it sound right to you? thought the 1.8 was 115 bhp?
    1.8 sri 123 bhp 0-60 8.5 year 2000
    2.0 sri 134 bhp 0-60 9.0??? year 1998
    2.2 sri 144 bhp 0-60 8.2 year 2000
    I thought the 1.8 was the slowest, not the 2l, and why if the 2l is more powerful is it slower?
    Old school ISCOOL!
    Sep 2005
    Cav SRi/BMW E30
    Yup sounds all spot on to me.
    Bishops Stortford
    2 seat 2.2 vxl
    1) I'd take the figures with a pinch of salt.
    2) its only half a second.
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    The early 1.8 SRIs upto 2000 (W) IIRC were 115 BHP, then they were given the Z18XE1 with 125BHP
    Out of interest what is the difference betweem the X18XE1 and Z18XE1 lump bar the power output, is a it a case of a vaux remap to 125 bhp or is it a completely different engine.
    3.0 V6 CDTI Vectra SRI
    You can't get thicker than a Kwik-fit fitter.
    MIGClub Member Sten's Avatar
    Jul 2005
    Paisley
    Vectra C GSi & Corsa C
    Again, the 1.8 engine was 113 then 123 bhp.
    The on road difference is zero though.
    >>>>>>Sten<<<<<<
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    ffs what diff does 2 bhp make, im using 115 as a ballpark figure
    Nov 2005
    Kent
    Quote Originally Posted by tommychimp View Post
    It was to do with the emissions...
    X = Euro 2
    Z = Euro 4
    The first digit of the code relates to the emissions regs the engine meets.
    Z = euro 4
    Y = euro 3
    X = euro 2
    C = euro 1
    Cars made before the emissions regulations have no letter at the start of the code.
    The next 2 digits are the capacity.
    For example, the 20 in C20 XE means 2 litre.
    The next letter is the compression ratio.
    G = 8 to 8.5:1
    L = 8.5 to 9:1
    N = 9 to 9.5:1
    S = 9.5 to 10:1
    X = 10 to 11.5:1
    Y = 11.5+:1
    The next digit relates to the fuelling.
    D = diesel
    E = multi-point injection
    Z = single-point injection
    V = carburettor
    Some engines have an extra code at the end, if they are different from normal
    For example:
    H = high output
    R = increase output
    T = turbo
    V = volume model
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    So the same engine, but I'm guessing a different cat and EGR system?
    Nov 2005
    Kent
    I'm not sure, probably the 2 cat thing some 1.8's have going on. Maybe.
    I know the Z20LET has a pre-cat and main cat...so that might go someway to explaining it.
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    Ah ok, I'll stick my head underneath and have a butchers tomorrow
    Bishops Stortford
    2 seat 2.2 vxl
    my "later" engined 1.8 has a close coupled cat, ie the cat is part of the exhaust manifold and the system bolts to the bottom of what would be the downpipe (but is the cat/manifold)
    Nov 2005
    Kent
    The pre-cat is immediately after the manifold. Can't miss it...
    Your car will definitely have a main cat underneath.
    Nov 2005
    Kent
    ^ or that lmao
    Apr 2006
    Telford
    Vectra SRi 3.0 V6
    Quote Originally Posted by astra_sri_andy View Post
    Stuck head under, from what i can see it only has the one cat and there is a very nice looking 4-2-1 manifold arrangement at the front although the manifold itself is very short.
  26. #25
    Nov 2005
    Kent
    I suppose the easiest way to tell is if you have a lambda sticking out of the manifold heat shield at the front.
